Results 1 to 15 of 17
Thread: 1jz to ma61 engine mounts
    May 2006
    Gawler west
    Default 1jz to ma61 engine mounts
    I have a 1985 ma61 and planning to put in 1jz-gtte, is there any one or any where that has made own engine mounts or have idea on dimensions and agles to make them? or is there any where that may have manufactured some to sell?
    Junior Member Backyard Mechanic STR8 2.8's Avatar
    Default Re: 1jz to ma61 engine mounts
    find a place called bonneville automotive, they make the mounts
    I have a Crown
    May 2006
    Gawler west
    Hey thanks heaps for that. should save a fair bit of time. cheers for help.!
    Today Im a Domestic Engineer Enchanter's Avatar
    Tas
    The number is listed in here.
    http://www.toymods.net/forums/showthread.php?t=2354
    Cheers, Tim
    Garage Queen Automotive Encyclopaedia ZZT231's Avatar
    Quote Originally Posted by simple61
    You better do that, and to be on the safe side, change/upgrade your suspension and change your brakes whilst you drop a different engine in the car.
    My engineer looked at the engine and transmission mountings in the car structually, how it ran with the factory ECU and other required checks for engineering to satisfy his criteria. It wasn't required for me to fit an Unleaded fuel restrictor as that's the only petrol avaliable at most fuel bowsers but I presume that would depend on the engineer. Most engineers I tried for my car wanted an Emissions Data Sheet, but the engineer I have engineered my engine before so no Emissions Data Sheet was required.
    Cheers.
    Can't afford it?... Don't buy/drive it...
    James (Viper_Nipplex), We will miss you - Rest In Peace - 11 March 2009
    May 2006
    Gawler west
    yeah definatley planning on upgrading the brakes, suspension has been upgraded slightly, but is hard to find what i want, or just plain costly. being an apprentice get paid little money to spend big. have been looking at some options to upgrade running gear though.
    the stock ma61 gbox/diff will handle 1jz power for a fair while, so you can put that closer to the bottom of your list of required mods
    I have a pet Backyard Mechanic Gibbon's Avatar
    Aug 2006
    ... and this is what they will look like
    [IMG][/IMG]
    wget -r http://www.toymods.net | grep -i "1jz MA61"
    1 Result found:
    Gibbons MA61 + 1JZ
    May 2006
    Gawler west
    Thanks gents, i have sourced the gearbox for the 1j, but most of the other running gear i will do a bit later down the track. was thinking of changing over to a 5 stud pattern on the wheels as its fairly hard to get the wheels i like with current pattern. but will just focus on the engine conversion for now. thanks for all of your input and pics you guys are really helpfull. cheers
    Even monkeys fall from trees!
    Wheels = Simmons FR17s
    Quote Originally Posted by Draven
    2nded... in 17x9 and 17x10.. or 11.. whatever you can fit/afford
    Damn those Bonneyville mounts look primative.
    Tas
    Yes, very basic.
    That pic has convinced me to make my own, bugger paying $300 for them.
    I'd still buy them.
    Saves a lot of hassle.
    Trust me on that.
    primitive yes, but they do the job and save a lot of mucking around
  1. MA70 --> JZA70 Conversion
  2. 1JZ - Check Engine Light - Please Help!
    By Danners in forum Tech and Conversions
    Last Post: 05-10-2006, 05:26 PM
