if you were to do anything, port it a little (for the heck of it), make up extractors, and a better intake and bugger off the carb for something slightly better... and then think about cam...
but it is still pushing.... uphill.
a thinner headgasket would be the very least of my thoughts.
original HG is maybe 0.8mm thick. each mm gives about 5cc change? in volume. so if you change to a 0.4mm gsaket (do they make copper/MLS that thin? you migth get 2.5cc change......
much easier to skim the head 1mm..... but still, unless you do the supporting things, the change in compression will be barely noticeable... as said previously...
byteme, get over it![]()
