What car is this in.
I did the heads in my V6 4runner (3vze) late last year. If I never have to do it again it will be too soon.
If the heads have been reco'ed then you wont need to do anything to them before you put them on.
Make sure the deck of the block is clean. Remove all of the old gasket. I rubbed the deck of the block down with an oil stone wet with WD40 just to clean it right up. You wont need to use anything on the gasket, just make sure everything is clean and dry and torque the heads down in the right sequence and to correct torque specs.
Another tip, don't tip the heads over to look at the combustion chambers after you get them back from being reco'ed as the shims can fall off the valves and you will have to reset the valve clearances. Yes, this is coming from experience
After you have it all back together, flush out the cooling and oil systems too, just to make sure there isn't any gunk in there that might cause problems.
Good luck with it.
