Page 5 of 7 FirstFirst ... 34567 LastLast
Results 61 to 75 of 95
Thread: 4AGE 100kw smallport turbo rebuild
  1. #61
    perth
    Default Re: 4AGE 100kw smallport turbo rebuild
    40 psi 4agte
    at this point you should be thinking hmmmmmm maybe i should just get a bigger motor .
    i no its great to get power from a widdle motor but sheesh u can only be so rich.
  2. #62
    Default Re: 4AGE 100kw smallport turbo rebuild - update with pics
    Hey, I haven't updated this in a while...here is the latest pics...block is done and hopefully going in this weekend:
    4AGTE 1990 Corolla SX
  3. #63
    S.A
    refresh my memory. Wat sort of HG are you using?
  4. #64
    SCE Copper head gasket, 0.062", 82mm bore size
  5. #65
    Quote Originally Posted by BoostBoy
    cool i didnt know SCE was making them! good to see there doing the 4ag
  6. #66
    Good work with the Arias pistons. The big thing which lets the stock GZE pistons down is the weight compared to the aftermarket jobbies. 8000rpm with boost is all well and good, but when you are talking rod stretch.....
    I would be interested to see how this would go with a 36mm restrictor.
  7. #67
    S.A
    Wouldnt happen to have a rough idea of the diff in weight between pistons ??????
    STD vs aftermarket
  8. #68
    i can give you weights for CP,SRP etc tomorro. have to get the trade books out of the garage!to bloody cold now.
    i would use ACL's over arias everytime. CP is all i use but SRP do good pistons aswell and the is nothing wrong with maule aswell.
    the crown thickness is a good indicator.
  9. #69
    S.A
    Yeah sweet m8. I have some GZE pistons i can weigh up to compare !
    so you like the acl forged jobbies? I can get them cheap! i was told by the rep that they are actually made by another company and acl grind their name off and re stamp them.
    Hence the machine mark on the inderside of the piston! I forget who he said actually makes them!
    I have ABSOLUTELY NO doubt as to the strength of the GZE piston ( they can take a huge punishment) but like taki said the weight may become an issue for other components as im getting very close to the 9000 rpm region !
  10. #70
    there made by maule! like all acl forgies are made by maule.maule make very good pistons. shame you cant get the anodised skirts in the 4ag ones like the 308 ones.
    another thing about ACL, there bearings are as good as any in the world.
    i use clevlite bearing because they do H series bearings. thats the only reason.
    they are all fine. the thicker crown gives you a higer saftey margin if you get a hicup in the system,with the added bonus of being able to shave and blend ones with a thicker crown and better alloy to get exact chamber CC
  11. #71
    Toymods Club Member Backyard Mechanic Big T's Avatar
    Yeah the GZE pistons are heavy bastards! I remember picking up a box of 4 CP pistons and they weighed about the same as a single GZE piston! If i knew what my build would eventually turn into... i probably would have gone a set of aftermarket jobbies.
    Eddie.
    4agte finally completed. 234rwkw @ 8125rpm. Tis fun
  12. #72
    ok well cp and the like dont have weights for the 4ag or imports and i dont have a set out to weigh them. the ACL's ar 351grams. but i have the weights for all written down somewere ill try and find it! lol have 15 removalist boxes packed with books and papers so dont hold your breath! but i will get them!lol
  13. #73
    Are those Arias slugs part no 1515403228 that they depict in their catalogue? They look completely different? Can you advise? Thx
  14. #74
    Quote Originally Posted by kingmick
    you mean Mahle?
  15. #75
    If you look at www.atomicspeedware.com where I ordered them, the part number is different.
    Last Post: 17-06-2008, 08:53 PM
  2. Turbo Preference for 4age
    By Megz in forum Tech and Conversions
    Last Post: 01-04-2006, 01:44 PM
  3. 20v 4AGE into AE92
    By dale_8888 in forum Tech and Conversions
    Last Post: 16-12-2005, 04:51 PM
