Page 4 of 12 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 178
Thread: Hilux front brakes
  1. #46
    Default Re: Hilux front brakes
    Here are measurements from my R32 rotors. Obviously GTS-T given that the diameter is 280mm.
    and side on
    Peter
  2. #47
    Quote Originally Posted by 1JZ~lux
    This is great info guys. I just measured the internal diameters of my standard rims.
    The narrowest point (close to the front) was 305mm and the widest point (at the back) was 345mm. It looks like it'll be a tight fit when you add the caliper to the rotor sizes.
    Some photos and the measurements of the ones you're using would be great infotechplus
    You need at least 295mm to accommodate the rotor and caliper. Depends on the alignment added by the spacer but you should be OK.
    Peter
  3. #48
    Quote Originally Posted by -==L=a=N=c=E==-
    we talking the stock 14" wheels here?
    If so, im in with a chance!
    Yeah I ment the 14" wheels.
    I'm going to do some more investigating of the internal wheel diameters on the stock 14s and see if can work out exactly where in the wheel the brakes will be sitting. Hopefully they'll be closer to the back where theres more space and I can fit one of the larger sizes.
  4. #49
    Rosewood
    Im chasing up my mate to borrow his set, see if i can fit them on with minimal issues.
  5. #50
    Dreamer Backyard Mechanic millsi's Avatar
    whats the difference between the gtr calipers and the gts-t calipers?
  6. #51
    R32 or R33?
    R32 GTR calipers are Brembo models, but with the same dimensions as GTST R33 calipers.
    R33 GTR calipers are also Brembos but much larger mounting radii.
  7. #52
    I thought only the V-Spec got the Brembos and the lower spec got the "Nissan" sumitomo calipers? The dba catalogue appears to confirm this.
    http://www.dba.com.au/dba_catalogue_...005_v3_web.pdf
    R32 GTST with nissan caliper = 280mm
    R32 GTR with nissan caliper = 296mm dia.
    R32,33,34 GTR with Brembo caliper = 324mm dia
    R33 GTST with nissan caliper = 296mm dia
    Check on the above link if you wish to confirm.
    Gawd the interchangeability of Nissan brake components makes me sick
  8. #53
    Hm, i thought that the R32 GTR (at least in initial revisions) had a 296mm rotor with a Brembo caliper.
    Ive certainly seen one with a brembo caliper and what looked to be a stock caliper bracket, but we were certainly fitting 296mm rotors.
    Admittedly it is possible that Nissan/Sumitomo took over from that after an initial period with the 296mm Brembo caliper.
  9. #54
    You can get GTR in V Spec and ? Spec with V Spec having more fruit eg the Brembos F+R.
    ...i've seen one with the stock caliper bracket..
    Hence my comment about interchangeability, the nissan brakes are easily interchangeable across a few models, the GTR brake upgrade to the brembos is one such option.
    One of my friends has a V spec model R32 GTR and most of the others he looked at before purchasing were the lower spec model with the Nissan calipers.
    Think of it like WRXs with STI and the lower end ones One has Brembo one has Poobaroo calipers
  10. #55
    was thinkn of going with r32 gtr calipers (if the sumitomos are better than the r32 gts-t) but i assum i will have to use the gts-t rotors?
  11. #56
    Quote Originally Posted by millsi
    The R32 caliper with "Nissan" cast on them is made by sumitomo (they make some of the calipers for toyotas and many other companies too).
    Your choice of caliper from a GTR is either the "Nissan" caliper as pictured in this thread by infotech or the Brembo caliper from a V Spec model which will need the larger rotor to match.
    Refer to the DBA catalogue for the rotor size differences.
    The rotors infotech has posted pics of are an R32 GTST rotor.
  12. #57
    practicing idiot Automotive Encyclopaedia sheepers's Avatar
    May 2006
    New Zealand
    i have an R32 GTR.
    stock GTR is nissan/ sumitomo calpers, V spec is brembo, same disc width for both but the V spec is 324 dia, stock is 294 dia . bolt pattern is the same. dont know about gtst, never delt with one.
    latter,
    sheepers.
  13. #58
    so could i use the r32 gtr nissan/sumitomo, calipers and discs on the hilux?
  14. #59
    Just use R33 GTST calipers, they are much easier to get and dont command the omgwtfGTRtax.
  15. #60
    lol! hektic!
    what size disc do i use though?
    By The Witzl in forum FAQ
  2. Toyota Part Numbers - Toyota PN# for common stuff
    Last Post: 23-05-2011, 09:54 AM
  3. Replies: 4
    Last Post: 08-09-2005, 12:17 PM
