Page 3 of 12 FirstFirst 12345 ... LastLast
Results 31 to 45 of 178
Thread: Hilux front brakes
    Dreamer Backyard Mechanic millsi's Avatar
    Default Re: Hilux front brakes
    Quote Originally Posted by infotechplus
    These are on Oz EBAY for $299 Buy Now plus Postage
    Peter
    sweet do you have a link, i cant seem to find them under r32 anything????
    ima tool found it! lol
    are the z32/r32 gtst the same as the r32 gtr calipers? or are the gtr calipers better?
    wa
    so you use the nissan rotors as well ???
    if so do these have the bolt holes for the front hubs
    Quote Originally Posted by ecotechilux
    The five lug holes or the small screw holes to hold the rotor on the hub?
    Peter
    Quote Originally Posted by -==L=a=N=c=E==-
    is it spaced further towards the wheel, or further away?
    could you use rotors with deeper hats to offset them?
    The spacer would move the caliper further away, or closer to the rotor, that is, outwards.
    Possibly, but you'd have to locate several rotors and just trial and error them until you found one. Easier to use the Nissan rotors.
    Peter
    wa
    Peter
    oh i worked it out but do you use nuts on the back of the rotor to hold the rotor to the hub
    Rosewood
    Peter
    nothing a DBA catalogue and a few measurements couldn't fix.
    The major question is will it fit under my wheels. That is yet to be seen. Cause i believe that the skylines came with 16" wheels standard to clear the brakes?
  8. #38
    Here are the different rotor sizes for the Skyline:
    Peter
  9. #39
    I don't think so.
    Peter
  10. #40
    This is great info guys. I just measured the internal diameters of my standard rims.
    The narrowest point (close to the front) was 305mm and the widest point (at the back) was 345mm. It looks like it'll be a tight fit when you add the caliper to the rotor sizes.
    Some photos and the measurements of the ones you're using would be great infotechplus
  11. #41
    Rosewood
    Quote Originally Posted by 1JZ~lux
    we talking the stock 14" wheels here?
    If so, im in with a chance!
  12. #42
    Bugger!
    What do you get Takai? I got seals, rubbers, O-rings, clips and lube for each piston in the Nissan set. I got them through the same place as I got the calipers and rotors (SSS Automotive).
    Regards,
    Peter
    Exactly the same Peter. Now im not 100% sure on this one, but my box for the kit came labelled as Toyota Hilux LN130, not Nissan R32.
    Will post more when i get to the other house.
  13. #43
    Rosewood
    for reference sake, this thread is coming in handy for caliper dimensions:
    http://toymods.net/forums/showthread...ake+dimensions
  14. #44
    I have Hilux caliper dimensions for that thread, but i dont have my main PC here, as im in the middle of moving.
    Will put them up ASAP.
  15. #45
    Rosewood
    those the big 4 pots or the single pots?
    By The Witzl in forum FAQ
  2. Toyota Part Numbers - Toyota PN# for common stuff
    Last Post: 23-05-2011, 09:54 AM
  3. Replies: 4
    Last Post: 08-09-2005, 12:17 PM
