Results 1 to 15 of 18
Thread: More 3TGTE Questions!!
    grease monkey Grease Monkey
    Wink More 3TGTE Questions!!
    Hey
    Im still trying to get my engine to run right but we are getting closer, someone was telling me that a need to run dropping resistors before the injectors, and i have checked my engine and wiring diagram and that arent on either, so does the 3tgte need these resistors? also i really need a 3tgte diagram (that isnt simons) to copy off and double check everything, so if anyone could help it would be really appreciated coz my car is giving me the shits....
    Default Re: More 3TGTE Questions!!
    what exactly is going wrong with your engine??
    Hey,
    well the engine is starting and runs, but misses badly and it dies shortly after that. Also it runs very rich on start up and then seems to lean out. but im a apprentice mechanic and the car is at my workshop and we have tested a lot of things including fuel, spark, dizzy,some of the wiring, AFM and TPS, and even had the ECU sent away to be tested which tested fine. So which brings me back to needing a factory 3tgte diagram as well as finding out if 3t's need dropping resistors, so lilcrash can you maybe check your engine out and see if you have dropping resistors? and how did you wire up your engine?
    Scott
    Hmm my poor memory tells me that 3tgte did not run an injector resistor. I'm 99.9% positive actually.
    After it starts, how long before it dies? I'm wondering if its only running on cold start injector?
    Get some aerostart and keep spraying that into the inlet and see if it keeps running.. Then you know it's fuel injector issue.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    well thanks for that turbora28, quite a few people have told me that it might be running on the cold start injector but if so, what is making the injectors not work? i know that the dizzy has a wire out of it into the igniter and on into the ECU which gives the injector pulse but we have tested that, and the injector relay which both seem to be fine. So any other ideas would be a great help...
    Scott
    Fuel injectors could be full of crap? possibly from a Dity/rusty fuel tank.
    Jordan
    Best idea is to get an injector test light, $10 or so I think from repco?
    Plug that into one of the injector plugs while the engine is running and see if its pulsing the injector.
    Otherwise u are in the dark.
    fwiw: i collected some 3T-GTE info for Simon who's in the TCC(Qld).
    I'll put it up here for the next few weeks - it a wiring diagram, knock-control wiring diagram, Microtech drawings and a F9M settings/map file for (i think) a haltech running "1.8L DOHC 8V Twin-Plug Turbo motor running 4x550cc injectors, T3-T4 turbo and intercooler".
    See here:
    http://members.optusnet.com.au/mkhal...T_engine_info/
    Also: http://users.chariot.net.au/~stmezz/3gte.htm (pin-outs for ECU)
    Also: http://www.geocities.com/MotorCity/P.../3T-GTEfi.html for pin-out info and info about the sensors.
    ok, just to say it again, everything lil thing like the injectors being dirty and pulsing right has been checked....injectors have been flow tested and cleaned, and then we checked that they were all working which they are....
    Thanks for your help chuckster, but those wiring diagrams on the mkhal...T site are straight from simons site, so thanks but i already have those...
    Also can anyone tell me if i need injector resistors or not?
    Normally Aspirated Domestic Engineer RT104GT's Avatar
    Quote Originally Posted by Ta22boy
    My memory is hazy but I dont think so as its not Bosch jetronic (NISSAN).
    The Pintara basic circuit will run a 3TGTE.
    Looking at all the circuits and technical assistance available in 2006 I can't believe we actually got one of these engines running in 1986 using a 2TGTEU computer and no outside assistance.
    You guys get it so easy these days
    1968 RT40S Corona 1600S series II (restore in progress)
    1973 RT104-MQFG 012604 Corona GT JDM (Owned since 1976 242000 km)
    1989 ST185-BLMVZ-0007199 Celica GT4 JDM (unmolested classic 95000 km)
    2012 ZN-6 86GT (shed find 5000 km in 6 years)
    You say the injectors have been checked and cleaned and pulsing etc.
    But have you checked with a injector test light to make sure the ECU is actually firing them?
    If so, when the engine starts to die as you say it does, is the ECU still firing the injectors?
    New Zealand
    Checked for vacuum leaks, the pipe to the AFM splits fairly easy. Will screw up for AFM readings big time.
    Callum
    Turbo RA28, Yeah we do still have a injector pulse at all times
    But what i really need to know is DOES A 3TGTE USE INJECTOR RESISTORS, Seriously can anyone out there tell me, coz this is a joke
    Scott
    No it doesn't use injector resistors. I already said that. Have just checked wiring diagram and confiming NO.
    My questions and everyone elses are to try and help diagnose the problem. It seems you are stuck on the idea it is power to injector problem. I seriously doubt this.
    So the injectors continue to pulse even though the engine stalls.
    Do you have access to a wideband 02 meter to check what is happening to the mixtures when the engine stalls? Is it leaning out? Or fueling right up?
    Have you tried giving the fuel pump constant power to eliminate anything to do with power to the pump via the circuit open relay?
    Hi Ta 22 boy
    It has to be something you have overlooked like - Have all the earth straps been reconnected
  1. 3TGTE diff (MA61 surpra), air con
    By Diz44zy in forum Tech and Conversions
    Last Post: 03-09-2006, 12:36 AM
  2. 3tgte oil pressure
    By jeffro in forum Tech and Conversions
    Last Post: 15-07-2006, 07:03 PM
  3. 3tgte ECU and turbo
    Last Post: 27-06-2006, 05:16 PM
