Regarding the turbo, If you get an intercooler that is a decent size for the ct20, you can run up to 12 psi safely. If you want to go for another turbo later, (t3 etc), the intercooler is already there. The plumbing changes would be minimal. If you go for a t3 straight up you are going to have to outlay more money because you are going to have to rectify the problem of the turbo manifold. Whether you get a custom one, (made or buy second hand), or modify the existing manifold with a flange adapter.
A ct26 will fit your existing manifold with minor alterations which may be a better solution, and is similar in size to a t3. It may be a similar price or even cheaper than getting the t3 rebuilt, as a turbo rebuild kit is going to cost a bit plus labour.
The cheapest I found I could buy an E6x for was $1180. The cheapest I found a wolf3d v4 for was $1100. I'm not to familiar with the micro product. Remember if you can't install the ecu yourself you have to add labour for install and tuning as well.
