2jz-ge water pump does not fit 1jz-gte.
I haven't changed water pumps so that is as much as I can tell you sorry.
Hi guys,
The water pump in my 1JZ Cressida (JZX81) is rattling like mad, and will die very soon (no leaks fortunately). Sounds like a crook bearing. It is one of the pumps that is meant to go to a fan that uses fluid to turn it, but those inlets and outlets are not used.
I've been told that a 2JZ-GE water pump fits, is this correct? Or do I need a 2JZ-GTE one? My car runs electric thermo fans.
Basically I just need the part numbers of everything I'll need to get my car up and running again before it dies on the side of the road and costs me a tow or a motor.
I had a look in Barned's thread (top thread BTW!) and he listed these parts (for a JZZ30 soarer). I might do the timing belt while I am at it. Do I need to take the crank pulley off to do the water pump? If so then I might do the crank seal while I am at it.
Does anyone know the prices (roughly) on these parts and whether they are also suitable for my JZX81 1JZ?
Shamelessly stolen from Barned's thread:
timing belt.....................................135684902 5
water pump.......................................1610049 846
timing belt tensioner............................1350546020
crankshaft seal..................................9031146001
thermostat.......................................9 091603093
Thermostat Gasket................................1632562010
upper thermostat housing gasket..................1634388400(confirming)
waterpump to thermostat housing o-rings x2.......9676124023(confirming) or an o-ring from cbc
bearing of the following dimensions will work: Width 21.9mm ID 2.62mm) (what is this for?)
244rwkw / 328hp @ 18psi
2JZ-GTE pump is what you need. 100% fits, seen it with my own eyes.
Cost $160-170
will be waiting for this reply... as my cressy wil need one of these as im doing away with stock jzx81 engine fan setup
Sorry about the formatting, but I just copied and pasted part of my parts listing..
Part Number Description Chassis Engine List Price +GST
90916-03093 Thermostat JZA-80 2JZ-GTE $20.75
16325-62010 Thermostat Seal JZA-80 2JZ-GTE $8.45
08889-80086 Coolant - Toyota RED 4 Litres N/A $34.75
96711-24016 Oil Pressure Relief O Ring JZA-80 2JZ-GTE $3.55
15131-46050 Oil Pressure Relief Valve JZA-80 2JZ-GTE $6.00
15132-46050 Oil Pressure Relief Spring JZA-80 2JZ-GTE $3.00
15133-46050 Oil Pressure Relief Plug JZA-80 2JZ-GTE $4.00
16100-49846 Water Pump JZA-80 2JZ-GTE $166.85
96761-24040 Water Pump O-Ring JZA-80 2JZ-GTE $3.55
91511-B0830 Water Pump Bolts JZA-80 2JZ-GTE $1.20
16325-46010 Water Pump Gasket JZA-80 2JZ-GTE $6.10
90311-48013 Wheel Bearing Seal - Front MX-83 N/A $19.40
43514-43010 Wheel Bearing Cap - Front MX-83 N/A $9.35
90179-22017 Wheel Hub Nut - Front MX-83 N/A $4.65
12311-46020 Engine Mount Left JZX-81 1JZ-GTE $120.00
12315-46020 Engine Mount Right JZX-81 1JZ-GTE $140.00
90915-YZZD2 Oil Filter JZA-80 2JZ-GTE $16.00
51441-22160 Engine lower Stone shield MX-83 7M-GE $73.00
11213-46020 Camshaft Cover Gasket - Exhaust JZA-80 2JZ-GTE $24.50
11214-46011 Camshaft Cover Gasket - Intake JZA-80 2JZ-GTE $24.50
11213-88400 Camshaft Cover Gasket - Intake & Exhaust JZA-80 1JZ-GTE $33.25
12264-46010 Camshaft Cover Oil Breather Hose JZA-80 2JZ-GTE $14.60
12263-46010 Camshaft Cover Oil Breather Hose JZA-80 2JZ-GTE $16.80
90210-07001 Camshaft Cover Bolt Seals JZA-80 1JZ-GTE & 2JZ-GTE $3.15
90311-38041 Camshaft Seal - Front JZX-81 1JZ-GTE $12.30
90311-40014 Camshaft Seal - Front JZA-80 2JZ-GTE $12.30
90980-11246 Coil Pack Loom Connector JZA-80 1JZGTE & 2JZ-GTE $9.35
08886-81015 Automatic Transmission Fluid - Type IV N/A $22.50
TIK20 Spark Plug - Iriduim N/A $16.80
13568-49025 Timing Belt JZX-81 1JZ-GTE $60.55
90311-46001 Crank Seal - Front JZA-80 1JZGTE & 2JZ-GTE $28.75
90311-90006 Crank Seal - Rear Main JZA-80 1JZGTE & 2JZ-GTE $63.50
04479-22040 Brake Caliper Kit MX-83 N/A $67.00
i had 2 threads floating around for that, one is for the guide, the other is for the gathering of parts and information.
take a look at this photo and then have a quick look at yours.
http://forums.toymods.org.au/index.p...b8ab4e4b69ac22
the water pump on the soarer has a discernable snout with ribs on it (the one on the left in the picture and the same as the one in the post above), the hydraulic style ones (as found on jza70's) are a much more expensive part to replace (the one on the right in the picture), so you are better off converting to the same one used as the JZZ30 also. it is the 2JZ-GTE that shares pumps with a 1JZ-GTE, not the 2JZ GE
if you convert you will need to get a pulley from somewhwere (plenty of jz's being wrecked and also can't be that expensive to have one made up i would have thought, still significantly cheaper than replacing the hydraulic assembly anyway).
have a look for the guide on how to do the 100k service, i think there is a picture of what needs to be pulled off, there are 2 covers on the front of the engine that needs to be removed to get to everything (so yes the crank needs to come off).
Rob do a search for what sort of water pump the JZX81 has on it's car (i am assuming hydraulic going from a jzx91) and see if you can find a part number just for the pulley that goes on the snout of the water pump for the jzz30.
And from memory the parts are around $400 (just under 4 months ago) including jzz30 style pump, cam and crank seals, timing belt, thermostat, timing belt pulley and accessories belt.
JZX81 pump is a hydro setup, same as the JZA70 Supra. Very complex, and has 2 versions also.Originally Posted by barned01
See below.
1JZ-GTE (non hydro) Pully for the JZZ30 has 2 versions
9105 - 9605 = 16371-46020
9608 - end production = 16371-46030
jason, can you do a pricing on those parts also?
Thanks heaps guysHow do I go about getting that pricing Southo?
that's standard toyota pricing, just walk in there with a friendly smile, get friendly and they should give you a couple of bucks more off that price.
you should have seen it before southo edited his post![]()
Castle Hill Toyota can do trade pricing for toymods members
im a regular so if you need a hand lemme know.
Barned... Yes.. I realised this and then had to edit the post - LOL
I had all my discounted prices on there too .... ooops..
is anyone interested in making a few packages up, ie with all the required bits and peices.
as i really want to get my cressy a new water pump.
Yeah, if there is enough interest, I'll speak to my dealer and see whjat sort of discount can be arranged...
How many are we looking at ???
Pump = the goods. Also change the cam seals while you're at it, and throw in a new thermostat.
