Page 4 of 25 FirstFirst ... 2345614 ... LastLast
Results 46 to 60 of 374
Thread: 1UZ-FE VVTi into IS200
  1. #46
    Default Re: 1UZ-FE VVTi into IS200
    Justen - you better start heading down then, I've given up, the 1G is going back in.
    Ed - just do it damnit
    TTUZ Lotus Elise by then
    Are there any road registered 1UZ clubmans?
    In the meantime, here's the tacked mounts. They seem to fit well
    They have since been welded up properly...
    ...and work has begun on the headers (Thanks to JMR ) - the driver's side (the hard side).
    Packaging constraints have determined their lengths, so they won't be equal - no2 on this side could be made longer if it was remade but it probably won't happen. The benefit is they all run on the block side of the steering shaft and clear that very well (no photos unfortunately). At the moment they come out without removing the engine mount but the steering uni has to be moved and all of the nuts can be placed over the studs in the installed position. (It's amazing how easily things come off on a 6 year old car... steering uni joint just slipped off in contrast to the one on the sprinter that took much imagination just to budge).
    The passenger side should be easier and it should be relatively simple to make them equal length.
    Quote Originally Posted by grahamd
    If you are using the LS400 ECU you may not have as many problems.
    On mine there is the fuel gauge jumping on 1/4tank jumps - it needs to see the 1G-FE injectors to gauge how much fuel has been used, the fuel economy gauge doesn't work at all - may be linked to the fuel gauge issue
    Ah yes, heard of that with the yellow sportscross. The economy gauge needs fuel usage (injector opening time information) and speed signal - if either of these are not available it won't work.
    If the speed signal is not available, the fuel gauge will jump around depending on acceleration of the vehicle - it must ignore the fuel sender signal if it detects significant changes in speed.
    Does your 1G ECU "think" the engine is running or "cranking" or just on, etc?
    If I need to use the 1G ECU for comms, I will endeavour to make it think it's running - ie make sure it has IGf, connect the two engine position signals, temp signals, map sensor, loads for outputs if required, etc. Possibly that way it will just find a fault with the VVTi not responding to changes and most other things, in theory, it should be happy with.
    the air-conditioning has some of the circuity bypassed at the moment to keep it working. The other issues I have are with the Autronic and not the Lexus side. Have now bought an oscilloscope to see what some of the signals look like to sort out the last few issues. Hope to get to work on it oer the Christmas break and may know some more of the answers.
    The air-con problem is very commone issue with engine swaps in the IS200.
    Did you hook up the lockup detector to the 1G ECU? What did you do to make it work?
    Let us know what you find out with the scope (They're beautiful pieces of equipment - luckily work has a fine selection).
    More updates as they happen
    Mos.
  2. #47
    Trust me Mos, i'd rather have the UZ in your car than the elsewhere
    Progress looks good...hope you have a Merry UZ Xmass.
    Gorilla Industries Conversion King Koffee-Black's Avatar
    looking good!
    JZA80 Turbo Time Attack Car - "Gorilla"
    JZA80 Turbo Street Car - "Silver Back"
    Lexus RX350 F Sport "Kid Hauler"
    Vitz - Supercharged "Chimp"
    HDJ80 Landcruiser "Baboon"
  4. #49
    Penrith BC
    Quote Originally Posted by Mos
    lol !! not... !!
    "my penis is THIS big"
    anyway - how to make a bunch of bent tubes....
    ../delete/ban
    tech moderator
  5. #50
    Thanks dude And thanks heaps JMR
    Mos.
  6. #51
    Quote Originally Posted by ed_jza80
    lol !! not... !!
    Hey, I bloody told you that is thickness NOT length buddy. You f#*king wish you had a weapon like that!
  7. #52
    There's a thought, want to make this challenge a menage a trois Ed? In the automotive sense of the phrase only of course
    You'll need an impartial judge of course, may i offer my services?
    (Quoted again for clarity on what i'm offering)
    Toymods Club Member
  8. #53
    Headers (by JMR) completed Neverending thanks to Jason from JMR for the amazing amount of work involved in this part of the project.
    Note the quality of the workmanship of the joints. Everything was TIG welded, including the outer and inner flange ports. The pipes (1 5/8") were extended to the diameter of the flange hole (1 3/4"), tigged, and ground flat.
    In their installed position:
    Mos.
  9. #54
    very nice!
    Are you going to have them ceramic coated?
  10. #55
    Looks awesome, kudos to JMR.
  11. #56
    Mos this is looking so sweet
    awesome work as always jason!
    KE38 - 2TG
    MS65 - 1UZ
  12. #57
    The pics really don't do the headers justice, I soiled yet another pair of work pants yesterday checkng them out on the hoist
    Honestly tho this is going to be one of the horniest IS200's around by a long shot.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  13. #58
    Quote Originally Posted by TheToyman75
    It's just waiting to rape something.
  14. #59
    Kudo's on those headers mate! That's some awsome custom work there. I wish i had the time and skill to learn how to do that. Keep up the great work
  15. #60
    I must have my head stuck in the sand, totally missed this thread and had no idea you were even planning this Last time we spoke you were talking 2J's
    Anyway, looks sensational, makes me want to go and put a 1UZ in my car now
    Great work on the mounts and to JMR for the sexy looking headers
    Last Post: 29-10-2021, 10:49 AM
