Results 16 to 17 of 17
Thread: Exhaust heat wrap
    Default Re: Exhaust heat wrap
    Quote Originally Posted by Matty P
    Aussie exhausts say that heat wrapping their dump pipes will void the warranty on them. Obviously they think it can have a detrimental effect?
    hands up those who have exercised a warranty for corrosion damage to their exhaust system?
    my only return work was the diff hitting the rear pipeing - and that was fixed for free without question ... i think a refusal to warranty an insulated system would only apply if you have ultra-thin (read: uber cheap and too thin in the first place) zorst piping.
    Quote Originally Posted by sprintrphile
    wrap will accelerate the rate of rusting of steel manifolds. a friend pulled his off only to find it was the only thing holding the headers together!! it was on for a while but the steel should last ages!
    i got my entire zorst manifold and turbo glowing red hot - resulting in the wrap melting into glass - the only failure from that attempt at stupidity was that my own weld-repair failed ... corrosion underneath wrapping isn't really an issue unless the piping is way too thin in the first place.
    fwiw: i've used ACL heat shield around the dump pipe ... it cost ~$50 from supacrap for a 290x700mm sheet - i've stood it off the surface of the pipe by about 4-5mm with some bolts welded onto the pipe which also serve as the mnount points for the shield. My quick test (run engine for 2 minutes) was that the dump pipe instantly burnt my finger-tip and the rear-side of the insulation was still cool to touch (which my other finger greater appreciated).
    You can buy it from Horsepowerinabox.com
    I use it, it works rather nicely..
    Facebook | LinkedIn
  1. Heat wrap?
    By ReQuieM in forum Tech and Conversions
    Last Post: 20-06-2006, 07:58 PM
  2. Hunting a particular SW20 exhaust
    By Lonewolf in forum Tech and Conversions
    Last Post: 04-05-2006, 01:33 AM
  3. Ceramic coated pistons
    By mic* in forum Tech and Conversions
    Last Post: 27-01-2006, 11:42 PM
