you will need the flexplate, the auto box, maybe a tailshaft. a trans cooler would be a good idea also, that means you need lines to match.
then remove the clutch pedal and fit the larger brake pedal.
do you know if these are electronically controlled transmissions? if so then you will need an auto ECU.
