you will need the flexplate, the auto box, maybe a tailshaft. a trans cooler would be a good idea also, that means you need lines to match.
then remove the clutch pedal and fit the larger brake pedal.
do you know if these are electronically controlled transmissions? if so then you will need an auto ECU.
once that is off, fit your flex plate and then lift up your auto trans....be sure the converter is seated properly and do NOT let the gearbox hang off the motor...keep it level or you will bend the flexplate... when you slide the auto trans on be sure that the converter centre slides into the centre hole on the flexplate otherwise u will damage sumthing if you do it up when its not aligned.once you have it up against the motor bolt up the trans mountso you dont have to hold it up and fit the 2 top bolts to the front of the trans and remove the support if its flush against the box all around. fit the rest of the bolts and the starter motor. now i know nothing bout hiluxs so someone else on hear will tell you if it has a kickdown cable or electronic changing. fit the selector arm to the bottom of the shifter, you will probably have to fit a new 1 with pot rivets, bu then again i dont know how hilux levers bolt in, personally i would just geta second hand B&M shifter for 100 bucks and fit that, but your auto lever probably has overdrive etc on it. anyways onward with the conversion, your pedal box has little pins holding the pedals on with circlips on each side of the rod. remove 1 side circlip and slide bar out and your clutch pedal should fall down, do the same with your brake and fit the brake pedal
