Results 16 to 30 of 56
Thread: 2JZ-GTE Supra & Aristo Differences Rundown
    Default Re: 2JZ-GTE Supra & Aristo Differences Rundown
    OK so make it a Manual JDM Supra then Its a Jap import manual 2JZ-GTE
    It sure as fuck isn't the same as the USDM Supra wiring diagram and what we received was a pre-workshop "loved" abortion made from 2 looms twist and taped together over and over again.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    Minor difference but the 3 pin plug on my supra 2jzgte alternator is different too the aristo one i have.
    1994 GZX90 Mark II 1GZ-FE V12
    Not just a regular Backyard Mechanic ProjectSleeper's Avatar
    Had this sitting here and forgot to upload it...
    http://motorsportfotos.com/Aristo_Production_Spec.pdf
    As you can see, August '94 was when a Passenger Airbag was available (as an option) - it was Standard from July '96. But there was ( for some unknown reason), a poverty pack available at the same time that had the following items deleted...
    Drivers Airbag
    Air Purifier
    Cruise Control
    CD Player
    ? Not sure why...
    Offset is king Grease Monkey monkeymajik's Avatar
    Awesome spreadsheet, thanks!
    Are you sure they didn't offer black in the 92-94 region? I have a 93 coming in, in black and it looks like original paint.
    monkeymajik
    "Recommended for those who prefer
    hot driving action and big angle drift."
    JDM Style Tuning - Super Late Braking Technique!
    Quote Originally Posted by Viper
    Same
    • Turbo (CT20B's)
    Pretty sure they are CT12B's
    Jordan
    Only 2JZ's sold in the US and UK have CT12B turbos. The JDM engine (ie the one relevant to most of us) has CT20A turbos.
    EDIT: just realised the first post incorrently states CT20B, which I think is the turbo used on late-model 3S-GTE's?
    Junior Member Domestic Engineer Viper's Avatar
    Woops, Sorry
    Fixed.
    Cheers Norbs
    Daily: '06 Liberty 3.0R specB
    Project Car : '84 MA61: 2JZ-GTE + 6 Speed
    N.S.W
    Sorry to dig up an oldish thread,
    But I have one question
    What he said; if you found an Aristo with an M/T ECU in it I'd guess it was a conversion. Yes there are a few of those floating around, I saw one at the ImportBitz workshop not long ago.
    Quote Originally Posted by cambelt1
    And any M/T ecu ,s that are found in a aristo will be supra ecu,s , with the few pin changes .
    Dave
    So if I was doing an Aristo 2J conversion, with an existing R154 gearbox, would I need to buy a JZA80 M/T ECU, and then rewire the harness to a jza80 ECU plug? or could I use the Aristo A/T ECU on a manual transmission car?
    Thanks
    Sam
    Auto ECU and loom will run a manual box with only minor changes to the wiring, which includes shorting the neutral start switch (among other things I belive, Mos can most likely confirm)
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    Yep, lots of people are running manual transmissions behind Aristo engines with auto ECU. Apart from the neutral start switch there are no changes required.
    N.S.W
    Great info,
    Thanks MR 1JZ and Norbie
    Looking at Supra and Aristo pinouts, the Supra ECU plug has ~ 120 pinouts, while the aristo ECU plug has ~55. Can anyone tell me why there is such a difference?
    The reason I ask is that eventually I will want to install an Apexi Power FC on the Aristo 2J.
    My question is, other than the pinouts\plugs being different on aristo and supra, would there be any other compatibility issues with running a power FC not designed for an Aristo?
    a power FC install will result in your aircon not working
    I know this becuase I had a supra ECU on my aristo for a week and the AC didnt work...
    it just so happened it was the hottest week on record for 2007 in adelaide too
    N.S.W
    Other than AC, how did the car run with Supra ECU?
    As for the AC, I don't see how the ECU would affect the AC, What calculations does the ECU make for the AC to work? I'm not sure if I will have the same issue as my car is an MA70 Supra.
    car ran great, went better and the auto shifted harder...i suspect the supra ECU has a more agressive fuel or timing map than the aristo
    if you are using the motor in a conversion then it wont matter...that same supra ecu is now in my mates MX83 with 2JZ and the aircon works fine...I thought you were using an aristo
    N.S.W
    Thats good info about the map differences with the 2 different ECU's. Would be curious to see dyno results from different ECU's used.
    How did you fit the Supra ECU into your Aristo? Did you make a harness adaptor or something else?
  1. NSW Supra Club : Christmas Party : Sunday 3/12/06 - Pics & Vid Up
    By Alchemist in forum Previous NSW Events
    Last Post: 04-12-2006, 08:55 PM
  2. 1jz to 2jz
  3. Replies: 0
    Last Post: 30-08-2005, 08:43 AM
