Results 16 to 30 of 32
Thread: 1g-fe / 1g-ge
    Hung like planet Pluto... Backyard Mechanic Rcubed's Avatar
    QLD!
    Default Re: 1g-fe / 1g-ge
    Quote Originally Posted by ed_jza80
    its still not a generalisable statement F vs G
    i don't even understand what ur trying to say. is 'generalisable ' an english word?
    none of my posts made any mention of performance. just the physical difference of the two engines. all of which can be seen in a parts catalog
    1. There's no point arguing with an idiot. They'll just drag you down to their level and beat you with experience
    2. Don't argue with an idiot; people watching may not be able to tell the difference
    Junior Member Domestic Engineer Karma Supra's Avatar
    Oxfordshire
    Quote Originally Posted by ta23-mbzq-nnr
    you are correct especially as the 1G-FE had at least 13 years more development. the 1G-GE ceased production in the early '90s
    Are you not confusing the FE with the UFE?
    Some kind of BMW
    '97 Hilux Surf SSR-X LTD
    ..::VVTi 1UZ-FE::..
    What he's saying is that generally the Toyota G heads are the performance-oriented ones, and the F heads are the economy ones.
    However, that is changing as Toyota is slowly realising that the narrow-angle heads are a better thing. For example, there are certain supposedly 'ecomony' F heads that's much better than the G performance heads with respect to potential for power output.
    Penrith BC
    also that the comment on siamesed ports can not be generalised accross F heads
    my 1uz F ports look the same as any G port ive peered down
    ../delete/ban
    tech moderator
    Penrith BC
    ../delete/ban
    tech moderator
    QLD!
    Quote Originally Posted by Billzilla
    thanks Bill. i accept what ur saying [and if that's Ed's intent too] in terms of performance. but that wasn't mentioned.
    the 1g-g has 12 inlet runners and the 1g-f [in an Altezza and i assume an IS200] has 6 [common port to two valves]. therefore they are not interchangeable.
    i haven't checked whether the exhaust manifolds are the same, but both are 6 port.
    prior to that wide vs narrow head [which implies different pistons], scissor gears - different cam belt, different water pumps. none of those statements is generalised and are quite specific to the differences.
    QLD!
    G means twin cams each driven by the cambelt and wide angle between the valves. F means narrow angle between valves [and therefore cams] and the exhaust is gear driven from the inlet cam. because the different valve angles the pistons are different.
    inlets are differnt as the F has siamesed ports and the G has individual runners.
    alright, i've re-read my quote above. the last statement is NOT general but refers to the 1G. i thought that seeing this thread was about the 1G that was understood. i obviously didn't expect that interpretation and have amended.
    Penrith BC
    well, it appears to atleast be an american word...
    gen·er·al·ize (jnr--lz)
    v. gen·er·al·ized, gen·er·al·iz·ing, gen·er·al·iz·es
    gener·al·iza·ble adj.
    gener·al·izer n.
    British, gen‧er‧al‧ise
    ../delete/ban
    tech moderator
    HHeLiBeBCNOFNeNaMgAlSiPS Backyard Mechanic
    gener·al·izer n.
    Apparently "pedantic" is an english word as well! Who'd have thought!
    you know what I mean this electric stream
    and my tears in league with the
    wires and energy and my machine
    this is my beautiful dream
    Junior Member 1st year Apprentice Bullfrog's Avatar
    victoria
    Just a general question if thats alright
    Any chance of getting the waterpump pics reposted or emailing them to me please.
    Hilux RN110
    1G-GZE Gen 3 Conversion currently underway
    Junior Member 1st year Apprentice beerbaron's Avatar
    Jan 2007
    sa
    according to MOS
    the 1ggte manifolds cannot be used on the 1gfe motor
    something to do with the spacing
    thanks Mos
    although i thought putting a 1g-gte motor in an is200 was illegal ( rego etc )
    Junior Member Backyard Mechanic SIKTOY's Avatar
    the 1ggze inlet only has 6 runners and bolts up to the gte
    reputation is nothing knowledge is everything
    RA23 1GGTE 12.3@110mph
    1980 RA40 now getting a 1G with new picsLOOK
    Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
    Feb 2009
    NZ
    Quote Originally Posted by beerbaron View Post
    according to MOS
    thanks Mos
    1GGTE exhaust manifold WILL fit on a non VVTi 1GFE.
    Just to confirm that pistons/rods are interchangeable between the 1ggte and 1gfe?
    RA23 - Twincharged
    JZZ20 - Daily
    QLD!
    Quote Originally Posted by Kedderz View Post
    fyi 10 char
