View Poll Results: Which ECU do you have?
Voters
178. You may not vote on this poll
  • Microtech
    26 14.61%
  • Adaptronic
    8 4.49%
  • Haltech
    14 7.87%
  • Motec
    14 7.87%
  • Wolf
    17 9.55%
  • Autronic
    16 8.99%
  • EMS
    17 9.55%
  • Power FC
    5 2.81%
  • Other (Please Specify)
    16 8.99%
  • Factory/No ECU
    45 25.28%
Page 7 of 7 FirstFirst ... 567
Results 91 to 99 of 99
Thread: What ECU do you use?
  1. #91
    Junior Member Domestic Engineer Hurricane's Avatar
    Default Re: What ECU do you use?
    yeah im thinkin the MS now cos cant be fuck waitin for more money now
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
  2. #92
    Brisbane
    A Microtech - simple, flexible and does the job perfectly.
  3. #93
    Junior Member Domestic Engineer Sprinterboy's Avatar
    Autronic SMC for me.
    Best thing i ever did!
    SprinterBoyAus on YouTube
    SprinterBoyAus on Facebook
  4. #94
    Tasmania
    had a LT10s (with x4 ignition module) in my 13b turbo ra23, easy installation and manuals are easy to read and follow (for a then first timer). And pretty cheap.
    using power fc pro in the 205, pretty happy with it, really need the datalogit to get the best from the ecu, but you can still get a good tune with the hand controller.
    Well priced, plug and play is a bonus, and launch control and hard and soft limiters are a good bonus.
    EDIT:the stock delco ecu in my work bomb camira is giving me dramas at the moment
    1973 TA22
  5. #95
    holy thread revival batman!
  6. #96
    Tasmania
    yep, seemed like a good idea at the time
    what did you end up gettin man? and are you happy with it?
    1973 TA22
  7. #97
    Seeing as how it's been given a bump
    I've got an E Manage Ultimate suplimenting my standard computer in my SC MR2. When I fitted my bigger airflow meter (same size as a 3SGTE but came from a 2.2ltr Mazda ), I used the Jaycar Digital Fuel Adjuster but couldn't lean out AFR's where I wanted to. EMU has an Airflow Meter correction map (16x16) but I never could get it to run propperly using that (prolly sumfing I haven't set up right), so I left the DFA adjuster in there and used the EMU's injector trim feature (16x16 map) to lean out AFR's and add some extra ignition aswell.
    Also used the speed/load fuel trim to give a lean cruise mode of about 15.5:1 for better ecconomy and the extra injector controller to provide a variable flow rate water injection control with the pump switched on also by the EMU.
    Best of all installation, set up and tuning was all done by yours truly
    PS I do have an Innovate AFR meter for tuning, so I wasn't cluching at straws or anything stupid like that . It's also compatable with the Autotune feature of the EMU.
  8. #98
    Another vote for Autronic SM4, in this case basically limited power tune but engine seems to run fine
    Mos.
  9. #99
    Mos.
  1. late 97 on hilux 3rz turbo conversion walk through
    Last Post: 07-01-2011, 07:10 AM
  2. turbo kits for 3RZ-FE
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 18-09-2006, 06:31 AM
  3. 3rzfe engine wiring diagram 98 model
    By BeRad in forum Tech and Conversions
    Last Post: 12-07-2006, 10:17 AM
  4. 1jz Aftermarket Ecu
    By thommo in forum Tech and Conversions
    Last Post: 27-01-2006, 09:09 AM
