Results 31 to 45 of 69
Thread: Beams 3sge Rwd
    W.A.
    Default Re: Beams 3sge Rwd
    Quote Originally Posted by 7MA61
    That be his radiator fool
    HAHA
    well it should be a cooler
    Controlling the vvti isnt really all that difficult all you need is 2 auxilairy outputs, motec, power fc i think, there are a few that will do 2 outputs, or just wire it up yourself to come on at 3 or 4 thou or woteva is the best spot. not that hard yo. tis only a solenoid.
    Hmm might go pick up the halfcut and have a tinker or at least start it up so i can hear it See wot it sounds like with no exhaust when vvti kicks in hehe
    Matty
    sel
    Question Re: Beams 3sge Rwd
    Quote Originally Posted by JustCallMeOrlando
    Given the complexity of the factory ECU and how locked down it probably is, I don't think you're going to have much luck. There is bound to be some product for it, how much resolution you'd get out of it I dunno. I'd either run the factory one, or suck it up and get an ECU.
    Hehe, Mr Orlando
    i havent done up my car yet... but im agreed with u to run it with the stock standard first b4 try any stupid thing...
    i found an URL to convert the MAF to MAP... but as u mentioned i doubt bout the resolution of the MAP compare with MAF... may b i will try out after i get my car done up...
    W.A.
    by the way Power FC do a plug and play for the red top (single vvti) cant see why they wouldnt do black top.
    Matty
    sel
    Cool Re: Beams 3sge Rwd
    i have a red top in my 90s silly kar as well... it is responsive n powerful enough without the additional accessory although the car itself is heavy (if compare with my friend AE101)...
    Quote Originally Posted by kanazai2001
    new yaris is called auris... using new 2ZRFE dual VVT-i 1.8L engine...
    I think you'll find the Auris is the new Corolla but nice try anyway... and the 2ZR-FE still isn't as good as the 2ZZ-GE
    sel
    Talking Re: Beams 3sge Rwd
    Quote Originally Posted by Blue_Stivo
    agreed... rated hp n torque are very low compare with 2ZZGE... but dual VVT-i sound interesting...
    Quote Originally Posted by Wildsupra
    Nada, a lot more complicated. VVT works like that, but the vvti solenoids are controlled via PWM, and have a range of angles they work through, and the ECU has to be able to keep track of, and control the angle over a variety of different loads/RPM. Much more complicated!
  8. #38
    Matty
    a quick scan of the apexera site brought up this for the power-FC and 3S-GE
    ○ アルテッツァ M/C後 SXE10 3S-GE '01.5~ 414-T013 SX10A FCC SX or FCC3
    ○ アルテッツァ M/C前 3S-GE '98.10~'01.4 414-T006 SXE10 FCC2 SX or FCC3
    ○ アルテッツァ(ターボ)M/C後 3S-GE '01.5~ 414-T014 SX10TA FCC2 SX or FCC3
    ○ アルテッツァ(ターボ)M/C前 3S-GE '98.10~'01.4 414-T010 SXE10T FCC2 SX or FCC3
    anyone?
    edit... formatting
  9. #39
    sorry folks, still looks like the BEAMS is gunna be the front runna, RWD that is.....
  10. #40
    HAHA
    Matty
    Yeh you may be able to do that with vvt. Not vvti. Vvti is constantly variable and not solely dependent on a certain switch point.
    edit- too slow
  11. #41
    Quote Originally Posted by gwh1946
    Mmmm, im looking forward to this one
  12. #42
    180 rwkW of BEAMS goodness.
  13. #43
    W.A.
    cant quite read the chassis plate, what car is that in? And with wot computer?
    dam that one has a cooler aswell!!!!! oh no hang on that is also a radiator
    Matty
  14. #44
    RA45GT Celica.
  15. #45
    W.A.
    serious, that is somewhat kinda rare isnt it.......and they un standardised it with a beams.....interesting.
    go the beams.
    Matty
  1. stock fwd beams 3sge dyno results
    Last Post: 29-11-2006, 12:53 AM
  2. 3sge exhaust for SW20
    By Lonewolf in forum Tech and Conversions
    Last Post: 13-10-2006, 07:18 AM
