Results 46 to 60 of 69
Thread: Beams 3sge Rwd
  1. #46
    Default Re: Beams 3sge Rwd
    He's on the forums Matty boy.
    Forgot, it's a Motec M800 isn't it Dave?
  2. #47
    sel
    Question Re: Beams 3sge Rwd
    Quote Originally Posted by gianttomato
    180 rwkW of BEAMS goodness.
    interesting...
    what ECU is this BEAMS running without MAF...?!
  3. #48
    Quote Originally Posted by kanazai2001
    interesting...
    Motec M800 with variable cam timing.
    Its Celica RA45s car, its a caged race car used for Supersprints
    Approx 180rwkw.
  4. #49
    W.A.
    Quote Originally Posted by JustCallMeOrlando
    Nada, a lot more complicated. VVT works like that, but the vvti solenoids are controlled via PWM, and have a range of angles they work through, and the ECU has to be able to keep track of, and control the angle over a variety of different loads/RPM. Much more complicated!
    hmm very gay
    ahh well full advance must be better yeah? hahahah just leave the biatch's on the whole time, sure it might idle like a pig
    Ask waynofx about the power fc's. i installed a beams redtop into his celica for him and he has just gone and ordered a plug and play for his. He may be able to help with the black top also.
    Matty
  5. #50
    Junior Member Grease Monkey go_the_datt's Avatar
    Approx 180rwkw.
    anymore specs on this engine? is it "un opened"?
    or about 180rwkw with just intake and zorst?
    sel
    Unhappy Re: Beams 3sge Rwd
    Approx 180rwkw.
    o... my god...
    then i can forget bout my 4 throttles n MAP dy...
    but 180whp... what is this engine rated power in hp n torque?!
  7. #52
    W.A.
    yeah does any1 know an actual factory power output??
    Ive heard 260hp but im a little skeptical.
    Either way, it should piss in a RA28
    If it doesnt we will just have to modify it
    Matty
  8. #53
    LOL. Yes it has been opened. Can't talk about specs but it's been tweaked in all the standard ways.
    If you look at the recent thread regarding the standard dyno figures then you'll realise there has been a significant amount of development.
    Std power is about 210hp for the manual and about 190 or 200 for the auto motor (flywheel figures of course).
  9. #54
    sel
    Cool Re: Beams 3sge Rwd
    Quote Originally Posted by Wildsupra
    Matty
    ori factory spec:
    Bore and Stroke: 86.0mm x 86.0 mm
    displacement: 1998cc
    compression rate: 11.5
    Max power (NETT): 154kW(210PS)@7600rpm
    Max torque (NETT): 216N.m(22.0kg-m)@6400rpm
  10. #55
    180rwkW dude
  11. #56
    sel
    Thumbs up Re: Beams 3sge Rwd
    180rwkW dude
    sorry... miss Q...
    180rwKW = 240rwHP...
    mean rated engine hp will be around 198kW/270hp?!
    is it TRD spec quad throttles 3SGE?
  12. #57
    I would be extremely surprised if Glenns car is only making 270hp at the engine. Stockers as shown before tend to make what 120 rwkw being very generous? So that's a 50% increase, minimum.
    Power FC do make a plug and play computer for the Altezza Beams engine it's the SXE10 one listed up above.
  13. #58
    The second prettiest man on ToyMods has it right. Not going to be many easy ways to change from MAF to MAP that i know of. Unless Bill knows some interesting tidbits with the specific BEAMS ECU?
    Nuh.
    <10char>
  14. #59
    Junior Member Domestic Engineer MRMOPARMAN's Avatar
    vic
    does anyone know how much a beams engine would weigh with intake and exhaust approx??
  15. #60
    Melbourne Victoria
    what are you putting it into its lighter than a 2tg and abit heavier than a 4ag about 20 kilos heavier sorry std motor is 35 kilos heavier than the 4ag
  1. stock fwd beams 3sge dyno results
    Last Post: 29-11-2006, 12:53 AM
  2. 3sge exhaust for SW20
    By Lonewolf in forum Tech and Conversions
    Last Post: 13-10-2006, 07:18 AM
