Results 61 to 75 of 84
Thread: 2JZ-GTE VVT-i FULLY OPERATIONAL
  1. #61
    The Supreme Backyard Mechanic
    Default Re: 2JZ-GTE VVT-i FULLY OPERATIONAL
    the wolf v500 should run vvti also....
    I have decided to go autronic after spending an hour chatting to Rod... leaves me money for other things....like turbo's.... and tyres....
  2. #62
    Forum Sponsor Automotive Encyclopaedia dori dori's Avatar
    Quote Originally Posted by teamdrinkalot
    So does the Haltech provide pulse to the VVT solenoid and depending engine conditions or just switches it on at a certain rpm?
    yes it varies the signal to the oil control valve which either advances or retards the inlet cam.
  3. #63
    KE70 7AGE Grease Monkey jet81j's Avatar
    love your soarer
    i want a 2j in my cressida now even know i have a 1j. All this talk about 2j's in your zoom mag makes me want one. do you think that VVT i is worth the expense or a non- VVT i would be just as good.
  4. #64
    A non-VVTi engine isn't as good because it doesn't have VVTi.
  5. #65
    If you can find a VVTi 2JZ grab it but i haven't seen many around.
  6. #66
    i think the cost would be a big factor.
    for the extra money you pay for a vvti engine, you could put into a non-vvti and make twice the power.
  7. #67
    Nay sayer Domestic Engineer Mr Ed's Avatar
    May 2006
    Quote Originally Posted by PlacentaJuan
    VVTi engines are newer too, less chance of getting a lemon that needs an expensive rebuild.
    Difference in price is only about $1000. Seeing as though youd be doing FMIC/exhaust on either engine that $1000 couldnt really go anywhere but a deposit on something nicer (ie turbo/ecu)
    Twice the power is somewhat of an exageration. 2JZs are great but it still costs more than a couple grand to get 400rwkw!!!
    I used to eat alot of natural foods. That was until I learned that most people died of natural causes.
  8. #68
    yeah
    based on my calculations, closer to $10k is what's required
  9. #69
    yea twice the power WAS an exageration, i just assumed people would realise.
    when i was looking for a 2j front cut i enquired about the vvt-i version too, i called over 20 places that advertise frontcuts and of the 2 or 3 that said they could get a vvti engine, they were over double the cost of a non-vvti. (but then again i dont have the contacts a lot of you guys have)
    put that extra cost into a non vvti 2j and what do you get?
  10. #70
    plus you have WAY less issues trying to control the bastard when you start sticking big turbos on the non-vvti
  11. #71
    May 2006
    Quote Originally Posted by Draven
    This is why I wouldnt bother with it exactly! Much broader choice of ECUs on a non-VVTi engine
  12. #72
    Junior Member Grease Monkey teamdrinkalot's Avatar
    Aug 2006
    Quote Originally Posted by dori dori
    Yes, but how does it vary the camshaft position when there is only a 12v solenoid valve which is either on or off?
  13. #73
    They don't - they use a three-position solenoid valve, and that's controlled by the ECU with reads the cam position from another sensor along each cam.
  14. #74
    Aug 2006
    Quote Originally Posted by Billzilla
    Thanks, but how does a 3 positional solenoid work if it has only two wires? Are the two wires 2 coil windings and they use the solenoid body as the earth/negative?
  15. #75
    I guess the power-off position of the solenoid is the nuetral position so oil doesn't flow so the cam doesn't move. Then the ECU would run either positive or negative to either wire as needed to move the solenoid either way to make the oil flow either way ..... ?
    Just guessing.
  1. 550cc US 2jz injectors into 1jz
    By Esselte in forum Tech and Conversions
    Last Post: 26-07-2007, 02:18 PM
  2. 1jz to 2jz
    Last Post: 30-11-2006, 07:52 AM
  3. 2JZ damaged, other options?
    By jzk25 in forum Tech and Conversions
    Last Post: 11-07-2006, 06:47 PM
  4. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
