not 100% sure on this, but I was looking into having this done on my RAV's 3S-GTE when it was in rebuild phase. From what I understand of it, the O-ringing is usually done on the block (though some go for the head) and uses a thin-gauge piano-wire or similar. The piano-wire is inset into small grooves machined around the outside of each cylinder bore and the wire put in place accordingly. Usually a shop that does specialty machining would be the go, and if you were in NSW I'd suggest you talk to Dominator, but I'm not sure who there is in VIC.
Again, not 100% sure on all this, but I hope some of it has helped.![]()
