That is a ke70 crossmember just has a section taken out of the middle to match the shortened rack.
jb_22 that should work but the bearing is large compared to the 22 housing and you need to factor in how you are going to join the firewall bit that is removable at the end of the column as you will be cutting this off this way. Bit fiddly but not impossible to solve.
