of note when putting in a corolla or sprinter crossmember in the difference in lower control arm width off the pivots is +32mm per side. This will not let the castor rod and anti-rol bar bolt back on. However if that 32mm is removed from the middle of the lower control arm not only will everything bolt back up but the car will have the same track.
i ALSO wouldn't have to mess around with engine mounts then either... cause it's what the engine came from... it's looking like a real option.
