Page 9 of 41 FirstFirst ... 789101119 ... LastLast
Results 121 to 135 of 604
Thread: TA22 + rack and pinion
  1. #121
    Default Re: TA22 + rack and pinion
    ST141 (i think) have knuckles with minimal offset, but are longer
    so is the plan a 323 slightly (like 5mm) shortened with low offset knuckles
    or shortened more and with higher offset knuckles
  2. #122
    I've heard rumors of mazda racks being used.. Looks like you put an end to that rumor and proved it's a go-er.
    With toyota inner rack ends, they are different thicknesses.. Maybe mazda the same? If you change a KE70 inner rack end to RA60 its hmm 5 - 10mm shorter.
    So that might be another area to get it a bit shorter.
    Don't want longer knuckles they will just give you less steering angle.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
  3. #123
    so im better off getting the rack shortened more and keeping the shorter/larger offset racks,
    I will get my mazda rack and see how much can be take out of it,
    This conversion is somthing i dreamed of never thought i would get nearly this far along
  4. #124
    Yeah stick with shorter knuckles.. As for the offset on them though, that changes Ackerman and i'm not qualified to suggest if more or less Ackerman is good. In the celica with my version 1 rack n pinion I had close to no Ackerman, car felt fine to drive, had the turning circle of a truck though. That was the only real difference I noticed.
    So if you can find a short knuckle with less offset you might be on a winner.
  5. #125
    Just did a remesure and i was measuring the wrong nuckles the STs are near 0 offset and same lenght, i was measuring RA40s and RT corona not RT and ST corona
    I have about 10 pairs of steering knukles now lol'
    STs look like they will be the win,
    What affect does longer LCAs have cause im running corona LCAs , just mean i need longer rod ends?
  6. #126
    Ha gets confusing hey having 101 different things laying around.
    ST141 knuckles dont fit RA28 struts though.. Not sure about TA22?
    But... ST141 struts can be a good thing as Nissan R32 calipers bolt to them so maybe st141 knuckles and struts?
    Longer LCA is a good thing.. the longer the arm the less geometry changes over a given amount of suspension travel.
    So a long arm you could be a little less picky about everything being spot on. If you are that way inclined of course! If you want it all dead set spot on ignore that last sentence.
    Longer tie rods yes, or use a 3 piece like RA celicas have where you have inner outer and a threaded tube in the centre. Just get a longer threaded tube in that case.
  7. #127
    Quote Originally Posted by TurboRA28
    Any details of the discs needed for this combo, i hadnt realised that this was the case.
  8. #128
    R32 calipers arent that flash
    the cast alloy flexxes under big load, for streetuse there great but i wouldnt have them on a track car, if the few KGs was that important i would go alighter rim, or a AP,willwood.brembo etc caliper
  9. #129
    I didn't get that far sorry.. Bolted caliper to strut and that was all..
  10. #130
    im using a ST strut already not a RA28,
    But i had RT knuckles initialy
  11. #131
    User Conversion King
    NWA
    ST141 is sposed to introduce some +ve camber on RA23/28/40
    ST141 and RT142 struts are the same as RA60/65 except they have solid rotors and ghey callipers.
    people with above coronas bolt on RA60/5 brakes though.
    hello
  12. #132
    hmm bloody hell i wonder what i have then. oh well ill dummy it all up and see what happens
  13. #133
    Joel you have done a R&P on 1 st gen right?
    any chance of pictures of steering colum-steering rack link, im just wondering how im going to do it ATM it looks like 2 unis and a short link but its gonna be intresting
  14. #134
    I have got my rack dummied up it looks alright to me, its on slotted holes with a choice of spacers and is going to go into the car (on stands) without springs to check for any mega bump steer or
    still help with steering colums and stuff would be good
    whats the technical side of mounting fwd/back and left/right?
  15. #135
    Hoppers Crossing
    FYi - Gemini rack mounts in front so no good on that count
    I've started looking into this as well. Need a TA22 K frame to start playing with
  1. Can you adjust steering stops with rack & pinion?
    By 1JZ-Rolla in forum Tech and Conversions
    Last Post: 22-07-2012, 01:30 AM
  2. rack and pinion steering - new pinion? from where?
    Last Post: 20-05-2006, 06:14 PM
