Page 7 of 41 FirstFirst ... 5678917 ... LastLast
Results 91 to 105 of 604
Thread: TA22 + rack and pinion
  1. #91
    Default Re: TA22 + rack and pinion
    Point noted... using a front mounted rack would probably add too much complexity to a conversion like this... unless you're already considering a dry sump that would clear it?
    any other rear mounted racks people know of?
    Vanman
  2. #92
    not forgetting the clash with the strut bar and swaybar.
    Stick with TOYOTA... mother knows best
  3. #93
    I have a good freind who i talked to yesterday about R+P in TA22s and back in the day he built one using a AE71 shortened Xmember and all the associated parts
  4. #94
    Merc, that is an option for sure.. If it all gets too hard trying to find a rack the right width. Get someone to cut the ends of the rack off and re-thread the ends of it for the inner tie rods.
    That would lose some steering lock though. So have to cut the housing also I suppose if that became a problem.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
  5. #95
    Quote Originally Posted by TurboRA28
    That is why I think turning down the ball ends by 20mm or so , is the way to go. Eliminates having to shorten the housing, after shortening the rack. Tis better for positioning the pinion as well, otherwise you tuck the pinion close to the centre line of the car. Could be a PITA with a wide engine.
    cheers Chuck.
    MS51Crown Coupe,
  6. #96
    but doing that means you would have to modify any future replacement parts in the same manner. rack is the least likely to wear out, so would be best to modify this to match the shortened xmember, and then be able to use standard parts everywhere else...
    vanman
  7. #97
    Quote Originally Posted by vanman
    vanman
    The man makes a damn good point.
  8. #98
    My little AE82 has exceeded 400,000 kilometres, without having to change any steering components. So I would suggest the above is a mute point.
    cheers Chuck.
    MS51Crown Coupe,
  9. #99
    That's pretty lucky if you've done all those 400,000klms yourself, and you know the standard parts are still in it. Most replacement steering components involving a ball joint only come with a 40-60,000klms warranty, and I haven't seen any of my own cars reach more than 200,000 without needing at least something in the steering replaced.
    The way I figure it in this conversion for a TA22, if you're already shortening the rack and the xmember, why not do them completely so you don't have to modify anything else? The less you change, the more it will act like the car it came from - completely predictable...
    vanman
  10. #100
    Junior Member Backyard Mechanic 71RA20's Avatar
    California
    You guys with TA22 Xmembers can just use your stock xmember thats what the guys over here are using. Also you Corolla guys. What we do is get all AE86 Manual Rack parts: Xmember, all brackets, steering colum, mounting plate on firewall, steering knuckles ans rack of course. It's done just like Big Flea did his Corolla. I'll look for the link GREAT info on his site on the swap.
    Cheers, Johnny
    An Eye for an Eye would leave the world Blind
  11. #101
    California
    Here you go
    http://www.1uzfe.com/
    Johnny
  12. #102
    any news info on how to pissoff the steering box is welcome info as far ass I'm concerned.
    Jordan
    P.S: has anyone considered using an AW11 manual rack?
  13. #103
    California
    Quote Originally Posted by jfallen
    Yes great substitute since AE86 Racks are getting harder and harder to find here in the States. KP61, AE86,AE71,AW11 are all good donors BUT all need a little twitching to work.
    Johnny
  14. #104
    AW11 rack is the same length as the very easy to get AE82 manual rack.
  15. #105
    Deal with the Frog Backyard Mechanic Cool1's Avatar
    Didn't we come to the conclusion earlier that they're not the same?
  1. Can you adjust steering stops with rack & pinion?
    By 1JZ-Rolla in forum Tech and Conversions
    Last Post: 22-07-2012, 01:30 AM
  2. rack and pinion steering - new pinion? from where?
    Last Post: 20-05-2006, 06:14 PM
