Results 1 to 4 of 4
Thread: SC14 belt runout
    Old Fart Backyard Mechanic dale30's Avatar
    Casino nsw
    Default SC14 belt runout
    Dont know if anybody has had this problem but i will throw it out there.
    While doing the sc/14 onto 18REGEU conversion i had to graft a rib belt pully onto the original water pump pully.
    with it tacked up i had zero runout but after i welded it... guess what it pulled.!!!
    Cut a long story short ive ended up with 12thou runout in both directions.
    Ive seen MUCH worse on v belts before without throwing a belt,but i dont know how much the ribbed belt can take without throwing a belt.
    Anybody had any experience with this.???
    I know i should havehad new ones turned up out of alloy but cant afford it.
    Or is there a ribbed pully that fits onto the rg water pump.??
    XT130 speedway car XT130 road car
    2 x Renault Fuego speedway cars
    02 TS50 falcon
    Light travels faster than sound. This is why some people appear bright until you hear them speak
    Jun 2006
    Default Re: SC14 belt runout
    If it is only 12 thou can you chuck it in a lathe and dress it into shape, the small amount you will be taking of will have little effect on strength.
    Are you running a common belt for water pump and supercharger?, most settups that I have seen have a belt specificaly for the supercharger to get maximum wrap on the pulleys, even then you need a fair bit of tension to stop them slipping.
    regards
    jon
    Casino nsw
    Quote Originally Posted by jonra23
    regards
    jon
    OOPs Never thought of that.
    Sounds like i better go back to the drawing board...
    02 TS50 falcon
    The stock GZE runs the WP with the SC belt, but it's not such a great idea. Try spacing your waterpump pulley out and running it off the front belt (if you've got one) If you get stuck let me know and I can do you a price on lathing up a custom pulley
    RM.
  1. twincharging prototypes needing constructive critisism (SC14 + turbo)
    Last Post: 11-10-2014, 01:02 AM
  2. my SC14 fitting guide
    By Adsport in forum Tech and Conversions
    Last Post: 06-01-2011, 12:04 AM
  3. squeeling noise from timing belt -4AGE- ITS BACK! :(
    By WHITCHY in forum Tech and Conversions
    Last Post: 13-01-2008, 07:42 PM
  4. 1GGTE power steering belt
    Last Post: 13-09-2006, 07:20 PM
  5. 4agze supercharger belt prob??
    By 4AGZE_rolla in forum Tech and Conversions
    Last Post: 02-07-2006, 04:50 AM
