Results 16 to 18 of 18
Thread: engine bore
    Junior Member Backyard Mechanic pete05's Avatar
    penrith nsw
    Default Re: engine bore
    Im going to try with a rattle gun today, just borrowed my dads. As for all you guys wonderful tips, thanks. The motor is currently sitting on the ground with no head on it or gear box so im hoping the gun is going to do the job!
    I also found a receipt for the car which says the motor had a refresh only 18 months ago, now the guy i took the head to says that usually means a re ring. Now that cost him $2500 so hopefully they would have done the bearings as well.
    Rip the sump of and pull a rod cap off. Soon tell you how the bearings are.
    penrith nsw
    well the bolt is undone and the flexi plate bolts are out also!
    I went to see the bloke about picking up the head and he hasnt even started it .
    Also had a lt of trouble with new flywheel bolts, took 4 goes for the clutch place to get the correct ones but, its all good cause i ended up with ARP ones.
  1. Toyota R Engine History
  2. MA70 --> JZA70 Conversion
  3. CV joints problem with bigger engine (FWD)
    By progkamol in forum Tech and Conversions
    Last Post: 15-08-2006, 03:00 PM
