Page 28 of 68 FirstFirst ... 18262728293038 ... LastLast
Results 406 to 420 of 1006
  1. #406
    Default Re: [Guide] Corona/Peugot/Hilux Conversion with Height Adjustable Coilovers [56k DIAF
    so sexy *drool* what ya minimum wheel size on that combo?
    Black Betty >HERE!<
    (\__/)
  2. #407
    Default Re: [Guide] Corona/Peugot/Hilux Conversion with Height Adjustable Coilovers [56k DIAF]
    Quote Originally Posted by ra_28
    Though i would throw up a couple of pics of my corona strut setup. TIt's made up of Corona struts, ms55 crown hubs, Holden AWD coupe 336mmx 32mm rotors and evo 7 calipers.
    That would be a killer combo.
    And that bracket is soo simple, could whip that up in no time.
    +rep for the idea!
  3. #408
    Alex
    Would it be possible to get a weight on the caliper? The bracket looks so easy to mill up. Can you get a dust shield on that at all?
    Also the main question needed to know. Did you machine the hub or disc at all?
  4. #409
    TA-022 I can get 17 inch wheels on with about 15mm to spare.
    CUZZO I'll trying to match a stone guard up not sure on what i'll use yet but there will be something out there. The weight of the caliper?? Good question they weigh less than the hilux calipers but the rotors are a lot heaver than peugot. The center hole on the rotor was machined out about 3mm and the pcd redrilled.
    Alex
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
  5. #410
    Just been having fun rebuilding the hilux calipers (FINALLY) and realised one caliper is missing the two "M" shaped wire clips that hold the brake pads in (these are held in by the pins).
    I'll be asking my supplier tomoz if they can get them, but does anyone have a spare set lying around they could help me out with? Probably unlikely but no harm asking. They are the caliper with 2 different sized pistons. Not the best example but its the clip shown at the very bottom of this pic:
    Oh and the RX7 pads I used (Bendix Ultimates) didnt need any mods to fit in the calipers.
    Also scored myself a Camry MC (actually an Aurion one but same shit I think... or at least hope)... so its all coming together now.....
    Toyota Car Club (Qld)
  6. #411
    victoria
    Lol-i lost one when i did my rebuild- just go do a 4wd wreckers tour, youll find one.
    have you put them on the discs yet? my drama wasnt getting the pads in the caliper, it was getting them in the caliper when it was on the disc. My rx7 pad fouled on the caliper just above the pistons and had to have some of the backing plate ground off, and then it was nun-spec getting it in. i finally hammered it in and it was so tight the front wheels just locked up when i drove it. had to linish em down before i could even drive it!
    though everything i do seems to be a bit more difficult than it is for my fellow toymodders
  7. #412
    Lol thanks for the advice I'll be dummy assembling everything up with the brakes before it goes in the car to make sure it all works, and to double check how much i need to take off the outside diameter of the rotors, so i'll make sure the pads fit right.
    My supplier cant get me some clips so i'll put up a wanted thread, but will probably have to go hunting wreckers I cant believe you cant get these new!! The other option was to try some brake shops.....
  8. #413
    Junior Member Backyard Mechanic Hash_ra23's Avatar
    Quote Originally Posted by sillycar chick
    There was a shop on ebay that have all the bits for the calipers but i cant remember what theyre called. They dont have the item listed on ebay but u can email them asking for that clip. Worth a try i think it was only a few bucks.
  9. #414
    Searched ebay stores for hilux brakes, can you remember if it was any of these?
    Roodogs 4WD Spares
    4x4world_store
    DRP Auto Brakes
    4WD Parts
    Ultra Cheap Auto
    BrakeWest
    Ringwood Auto Parts
    Sunbury Brakes Hardcore Clutch
  10. #415
    Junior Member Grease Monkey Chris's Avatar
    I was missing those "m" type clips as well and the pins that hold in the brake pads....i couldn't find them anywhere so i went stright to toyota and picked them up for about $20 for 4 pins and 2 clips.
  11. #416
    Also i just finished my set up...this guide was very helpful...here it what it looks like:
    its going into a ke35 corolla.
  12. #417
    Forum Sponsor Conversion King
    just wondering what shock and spring combos ppl have used in there setups.
    have to do a set for a customer for a road car, i know what to put in a track car just wondering ppls experiences for street?
    linden
  13. #418
    im running a kyb camary shock with 300lb/inch springs
    thats in a ke30 with a 1ggte
    KE38 - 2TG
    MS65 - 1UZ
  14. #419
    selbys springs .... pedders vrs strut inserts ... bit harsh but perfect track / street compromise on a budget i thing ... heaps less body roll but no no roll.... if ya get my drift
    Black Betty >HERE!<
    (\__/)
  15. #420
    Roodogs 4WD Spares
    4x4world_store
    DRP Auto Brakes
    4WD Parts
    Ultra Cheap Auto
    BrakeWest
    Ringwood Auto Parts
    im fairly sure its 4x4world_store. You can get them from toyota too but this place im pretty sure will be cheaper.
