Page 14 of 15 FirstFirst ... 412131415 LastLast
Results 196 to 210 of 220
Thread: 1st GEN Celica Surge Tank Ideas
  1. #196
    Default Re: 1st GEN Celica Surge Tank Ideas
    Quote Originally Posted by fade-e
    ... im not exactly sure how i am going to vent it out... i was thinking of going through the rear quarter vents on both sides, under the car...
    there are a heap of options, im just not too sure which im going to use
    Just drill a hole straight down through to underneath the car and run a hose through it.
    Easy.
  2. #197
    Argh... why did i ever decide to use 3/8ths bundy for my fuel lines!!!
    What a bastard to bend.
    5hrs later, one line bent and installed... 2 more to go.
  3. #198
    nice and neat ... worth it imho.
    Black Betty >HERE!<
    (\__/)
  4. #199
    Forum Sponsor Conversion King
    Dec 2006
    Quote Originally Posted by MWP
    life would have been much easier if you used alloy line, its so easy to bend
    linden
  5. #200
    Didnt even consider it...
    Wouldnt alloy be more prone to cracking and work-hardening like copper?
  6. #201
    Dec 2006
    i havn't had a prob with it, but i secure it to the body with Pclips every 300mm or so.
    its anealed so it bends easily with the benders i use (or around a pipe) but would probably crush if you tried to do it around your thumb tightly.
    linden
    ps: on my car it took me 35mins to do.
    pipes x2 bent holes drilled+rivnutted then all Pclips bolted up
  7. #202
    Mad Man Grease Monkey 77GZE's Avatar
    Has there been any more succsess on intake ideas to avoid surge tanks at all?
    Cheers, Steve
    1jz ra28 - AKA - Tyer Fryer
    1984 ma61 - stock and slow - ACE condition
  8. #203
    Dont think so...
    Youll find that a lot of race cars with EFI tanks still use surge tanks.
    Ie, its very difficult to make an in tank pickup surge proof, so surge tanks are the way to go.
  9. #204
    Has anybody else investigated the CIvic pump idea further?
    Quote Originally Posted by worldwalker
    heres a couple of shots of the civic pump and pot against the 28 tank
    ([][][]II--LT--II[][][])
  10. #205
    I reckon MWP's solution is still the best. The intank idea is nice, but i'd probably only trust it as a prime pump for a car that sees a lot of track time. Just IMHO
    1996 FZJ80 Landcruiser.
    Email : [email protected]
  11. #206
    Agreed... There's no way I'm running my car without a surge tank for what I plan to do with it, but a nice simple idea maybe useful for others...
  12. #207
    Intank surge tank, but it requires a lot of tank mods (might even do something like that for the 28 though, and will be doing a full custom tank for the 23)
  13. #208
    Anybody tried the teflon lined fuel hose? Not the braided stainless hose with teflon inner, there is apparently a rubber hose that has a teflon liner, to eliminate any fuel vapour passing through the hose wall. More expensive than most, but if you already have a boot-mounted system then it has got to be an easier option than relocating the lot?
  14. #209
    Mar 2008
    Just dusting the cobwebs off this thread...
    Anyone had more success with different surge tank setups??
    I'm currently planning mine now, tossing up between the spare tyre well or under the car. My engineer wants it all completely sealed (as per usual) and to have a drainage system in place (also as per usual).
    So far, I've got a horizontally opposed surge tank, VL turbo in-line bosch pump, electric carby pump for the pickup, and a filter for each pump.
    Been furiously searching the net for pics of other peoples setups, but it would be nice to see a backyard job, that satisfies the engineering requirements above, and utilises the spare wheel well or the space below the factory jack location.
    Al
    '77 YAMAHA XT500 - Project
    The Drivers' Vault
  15. #210
    Junior Member Domestic Engineer TA22 GT's Avatar
    Check this link for what I did on my TA22.
    http://users.chariot.net.au/~stmezz/simons.htm
    Check around Feb 2001 on my site.
    I got a tank from the US and fitted a high flow pump straight in. The tanks has baffles stock and wit ha bit of fiddling I work out perfectly with no need for external pots etc.
    Simon
  1. Min size of an effective surge tank?
    By thomasbl in forum Tech and Conversions
    Last Post: 03-07-2006, 12:38 AM
  2. how to fit a surge tank?
    Last Post: 27-05-2006, 08:29 PM
  3. Replies: 1
    Last Post: 13-12-2005, 03:42 PM
