Results 16 to 24 of 24
Thread: 3tgte conversion
    Junior Member Backyard Mechanic kugzs's Avatar
    Default Re: 3tgte conversion
    i think i figured it out.
    the brackets on the passenger side are different from stock 2t mounts. i think this is responsible for the angles being out.
    Jase do you know if the passengers bracket was custom made?
    Only problem is that it looks like i will need to replace a hose if i put on the stock bracket, but meh, at least i solved the problem of the engine mounts.
    I don't recall if the passenger bracket was a custom. Good to hear that you got it sorted.
    Texas Hold'em Junky Backyard Mechanic fade-e's Avatar
    thats strange, i had no issues with brackets being different in my '22 3TGTEU conversion... all i had to do was reweld the bracket 2" outwards and it fit straight in
    the 2" reweld was to accomodate for the turbo oil return line, other than that both sides sit perfect
    well mt 3t came out of a KE corolla.
    so it might have had custom brackets.
    fingers crossed it will be fine now
    hope so
    Kugzs,
    I was thinking (dangerous I know), but you haven't yet unbolted the mounts of your 3TC and bolted them to the 3T GTE, have you?
    You're right that the engine may have something different/custom on it, because it was originally done for a 2TG in the KE.
    I am certain that your 3TC brackets will bolt to the block. I have just finished modifying one such TA22 bracket over here to brace the turbo. And I have noticed that the TA22 mounts are quite different to the 3T GTE.
    Jase
    Kugs,
    If you need some clarrification a Certain turbo, manifold dump pipe, engine mounts and bracing are all mock assembled on a workbench near you Its complete with TA22 engine mounts and modified turbo oil drain
    Give Jason a call
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    stupidly i solm my 3tc with the brackets still attached. But the 2t ones look like they will fit.
    Ill see how they go and if there are still problems, ill come and see you jase.
    cheers for the help guys
    josh
    Kugs,
    2T TA22 brackets will work perfectly.
    Here is a pic or two from my phone.
  1. MA61 - RA65 Struts & Powersteering Arms conversion
    Last Post: 04-06-2013, 09:38 PM
  2. MZ20 - 7MGTE To 1JZGTE Conversion Pics (56K Warning)
    By Danners in forum Engine & Driveline Conversions
    Last Post: 07-05-2008, 10:02 AM
  3. MA70 --> JZA70 Conversion
  4. 3tgte oil pressure
    By jeffro in forum Tech and Conversions
    Last Post: 15-07-2006, 06:03 PM
