Results 1 to 15 of 24
Thread: 3tgte conversion
    Junior Member Backyard Mechanic kugzs's Avatar
    Default 3tgte conversion
    I am starting to fit a 3tgteu to a ta22 celica that had a 3t-c in it. The 3tgte that im putting in has a ct26 so i dont think i should need to move the mounts. I would have thought that since the 3t-c was in there that the 3tgte would bolt straight in.
    see here
    http://users.chariot.net.au/~stmezz/3tginfo.htm
    however i have run into a problem. It looks like the mount that are connected to the engine are to angle (close to vertical) compare with the brackets on the crossmember. Any ideas?
    thanks
    Default Re: 3tgte conversion
    i drew a diagram of the situation. if you reckon that would enable you to help me ill email it to you. i dont know how to post it up.
    Junior Member Backyard Mechanic jonra23's Avatar
    Jun 2006
    Try http://imageshack.us/ for hosting pics, then link to post.
    reagrds
    jon
    its not a pic its a word document (i drew a crap picture using word)
    Hoppers Crossing
    i used the the original mounts from the 2T and modified the turbo drain so it points up on more of an angle.......problem solved.
    any pics grega.
    took a photo of my drawing.
    http://img506.imageshack.us/img506/8...problemot9.jpg
    the angles of the engine mounts and brackets have been exagerated.
    Classic Not Plastic Domestic Engineer ace's Avatar
    The 2T (or in ur case, 3T) mounts should bolt up to the engine and the crossmember? I've never tried it though, just thought that was what most people did...
    My TA22
    Quote Originally Posted by gianttomato about new cars
    Yeah sure, it goes alright and it's got air conditioning, cup holders and automatic tampon removers, but where's the charm?
    Hoppers Crossing
    kugzs, sorry no
    i can photo the 2T mounts on the 3TG and show you the modified return pipe if you want. let me know
    yeh thanks grega, why not.
    Did you have a look at the drawing i did. Were you in a similar situation?
    thanks again
    That web page is great if you want to put a 3tgte in a TA22 but i can't seem to find any RA28 specific info.
    Youll have to let me know how you went.
    Jun 2006
    The easiest way into a RA series celica is to get a TA23 crossmemeber which Toyota used to run out its T series drivelines.
    Allows the T series engines to bolt up with original sumps etc.
    In the for sale forums there was a guy parting out a TA23, may still have crossmember for sale.
    regards
    jon
    Kugzs - you should (as already pointed out) be able to take the mounts off your original 3T C and fit them to the 3T GTE.
    The oil return should pose no problem with that set up. But let me know if it does and I will come over and offer assistance.
    IF you need anything done with the oil return you can bring it (and the engine mount) over and I can put it all on a dummy 3T GTE that I have set up in the factory.
    Regards
    Jase (ps if I seent this earlier I could've organised to come over tonight).
    hey jase,
    check out my pic in an above post. No lines or anything are in the way, just the angles of the mounts are preventing the the engine from sitting where it should.
    The rubber part of the mounts on johns 3tgte were identical to the rubber mounts on mine. Just the metal brackets on which the rubber parts sit are different angles. Ive now got some 2t mounts (just in case the ones that the 3tc were sitting on are different) so ill see how they go.
    if i still cant get it right then maybe ill need you to have a look, or if you are passing throuh anytime, let me know and you can have a look anyway.
    Hoppers Crossing
    um, the drivers side mount - no prob - you need to bend an oil return out of the way but no issue there.
    the passenger side mount is a different story........the oil return goes thru the middle and the return fouls where the rubber insulator bolts up. i cut 20mm off the base of the return pipe and moved it closer in - no problem. needs photoze to explain
  1. MA61 - RA65 Struts & Powersteering Arms conversion
    Last Post: 04-06-2013, 10:38 PM
  2. MZ20 - 7MGTE To 1JZGTE Conversion Pics (56K Warning)
    By Danners in forum Engine & Driveline Conversions
    Last Post: 07-05-2008, 11:02 AM
  3. MA70 --> JZA70 Conversion
  4. 3tgte oil pressure
    By jeffro in forum Tech and Conversions
    Last Post: 15-07-2006, 07:03 PM
