Results 1 to 15 of 29
Thread: swaybar tech. twin swaybars?
    currently toyotaless Grease Monkey rn-85's Avatar
    Canturbury
    Default swaybar tech. twin swaybars?
    ive been lookin around gathering info for the buget suspention setup for my ae82 and was curious on the posibilitys of eather -clamping two swaybars together: this was done by a guy on the old forums but i can find the thread back, it suposedly highly increaces the action (or lack there of)
    -going to a spring place and getting the swaybar retemped
    isn't a swaybar basicly a spring working horisontaly? so the spring works should be able to make it harder to some extent.
    -getting the spring works to make me a new swaybar out of thicker steel using the old one as dimentions.
    Junior Member Backyard Mechanic M.J.H's Avatar
    Default Re: swaybar tech. twin swaybars?
    Quote Originally Posted by rn-85
    That is probably the best bet.
    Rosewood
    Space might be an issue with twinbars. I was looking at something similar for my hilux. But twin bars might interfere with my torsion bars.
    I'm with MJH. Get a single thicker bar.
    seeyuzz
    river
    Junior Member Backyard Mechanic jonra23's Avatar
    Jun 2006
    Option 4, buy one from Whiteline, part number BTF65, 22mm dia.
    www.whiteline.com.au
    To work out increase in stiffness ((New diameter/current diameter)^4)-1.
    Whiteline unit is 22mm, i think original is 18mm so:
    (22/18)^4=2.23-1=1.23 so 123% increase in stiffness.
    regards
    jon
    make one yourself, then you will know it wont rub on your tyres, and if it oes its your fault.
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    Altia ER34 GTT Domestic Engineer JetspeedCamry's Avatar
    Quote Originally Posted by jonra23
    regards
    jon
    Is that actualy 123% increase? meaning...double + 23%? or....just 23% increase over standard...
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
    Jun 2006
    123% increase, the -1 in the formula subtracts the current swaybar stiffness.
    regards
    jon
    Canturbury
    is it cheaper to buy a whitline or get one made at 123% stiffer? and can the average spring works make one? to a desent quality?
    Jun 2006
    Whiteline list price is $213, doubt if you could get a one off built for that $,
    If you go onto whitleine web site ( I posted link earlier), up in the top left put in toyota, then corrloa, then ae82 will show all the items that they sell for your car, click on link for each item and it will show list prices.
    regards
    jon
    We used to do this in the good old days when you could only get bars for popular cars. My friend and I ran twin bars on our Corona Mk2 and Crown. I now just get a bar made up - was about 260.
    Given that Whiteline have a listing, I suggest you chat to them and see what combo works. Stiffening the front might just make the AE82 understeer even more. These shopping trolleys used to be raced so there is a bit of knowledge out there.
    I ran twin swaybars in the rear of my MX62.
    The price was right, and the results seems OK to me
    what? Automotive Encyclopaedia EVOSTi's Avatar
    on my budget ae71 drifter i run twin bars in the rear, made a noticable difference to handling. cost me $4 for two clamps, already had another standard bar lying around.
    has no Toyota anymore :( Conversion King tooch's Avatar
    Quote Originally Posted by gianttomato
    Yup, definitely do the rear swaybar rather than the front, makes the car a whole lot more balanced, and can actually get it into oversteer pretty easily. Had a heap of fun in my old AE82 with its whiteline rear bar
    Junior Member Domestic Engineer Hurricane's Avatar
    any one got any idea what a full costum sway bar would cost? cos i need one made up for my KE20 now that it cant be in the old spot any more
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
  1. Tacho tech
    By Hen in forum Tech and Conversions
    Last Post: 04-08-2009, 05:10 PM
  2. Which twin coils for 3T GTE ?
    Last Post: 26-07-2006, 11:43 PM
  3. html in the tech section
    Last Post: 28-12-2005, 11:49 PM
  4. Guidelines: Posting in Tech and Conversions
    Last Post: 20-09-2005, 05:42 PM
