Results 16 to 29 of 29
Thread: swaybar tech. twin swaybars?
    currently toyotaless Grease Monkey rn-85's Avatar
    Canturbury
    Default Re: swaybar tech. twin swaybars?
    got the twin swaybar setup sorted on the weekend, and it's harder to let the backend slide however when it does it goes out harder than if it had a single swaybar. i think that is the idea, isnt it? i tested it on some gravel and on testing it it held realy well so i tested it harder and upon that i slid it into a gutter removing a guide post and stoped after a stunning recovery facing the other way. twin swaybars:*** three stars.
    is there a panel beating tech artical?
    TRB01J Backyard Mechanic jak's Avatar
    Jun 2007
    sorry to be reviving an old thread, but rather than starting a new one....
    would anyone happen to have any pics of the clamping system they used on a twin swaybar setup and/or the whole setup installed?
    what kind of clamps have people used?
    Jak
    '77 RA28 Celica - Repairing Rust...
    '84 AE71 Daily Driver/Race Car
    '91 MX83 - Fastest Standard Turbo 1JZ Powered Vehicle In The World -
    10.74 @124 Mph
    http://www.youtube.com/watch?v=H2ido6yirZ8
    Forking Architect Grease Monkey
    Jan 2009
    S.A.
    twin swaybar = 100% increase over standard (obviously) and a whole lot of messing around...probably a coupole of weekends worth..
    ...just buy the pre-made whitleline one, and get brand new bushes etc with is too
    Rotaries are cool...so why are their owners such cocks>>?
    Jun 2007
    im going for a bullshit handling setup on my ae71 its already got a tercel rear bar with new ish bushes and im about to do a whole lot of work on the front end but i would like to add another in the rear coz its a budget job. Thing should drive like its on rails.
    ive got plenty of time to do it just want to see what one looks like.
    Jak
    10.74 @124 Mph
    I used 4 pairs of stock mounts, with plates in between the halves.
    I.e. Where the sway bar usually bolts to the frame there is a 'D' shaped metal bracket. For each of the 4 places that I mounted the bars to each other I had two 'stock' metal brackets, two bushes, a metal plate and bolts/nuts.
    You can also get some adjustment based on where you secure the bars to each other... closer to the ends = stiffer (longer lever)... etc
    Make sense?
    Wilbo's JZA80
    Wilbo's JZZ12
    Jun 2007
    perfect, exactly what i was after. + rep.
    this is sounding doable.
    except where does it bolt to on the diff? via the metal plate im guessing? What about the ends of the second bar?
    Jak
    10.74 @124 Mph
    Jun 2007
    sorry, double post
    Cheers for the help
    Jak
    10.74 @124 Mph
    i dont have pics of the links unfortunately
    but they are each just 2 alloy blocks, clamped together by a bolt in the middle with 2 holes drilled through them for the sway bars.
    takes a couple of hours and all done.
    edit: for the ends of the bar jsut cut them off as close to the end as you can, without them fouling on anything.
    also note that moving the links in or out will change the stiffness of the setup (out = stiffer)
    Jun 2007
    so the ends of the second bar dont bolt to anywhere?
    and the clamps holding the 2 bars together dont bolt to the diff like the standard mounts?
    Jak
    10.74 @124 Mph
    Quote Originally Posted by andrew_mx83
    Unless i'm misunderstanding you, you've got that around the wrong way; links attached further out on the bar (away from the mounts it pivots in) makes the bar softer. A shorter moment arm makes the bar stiffer.
    Toymods Club Member
    no the end just hang there but check the range they will move and make sure they dont foul on anything.
    just clamp the second bar to the first -the cressida one doesnt bolt to the diff so not really sure for yours but the general theory is just to clamp the actual bars together.
    gt - you may be right i have actually not played with the stiffness just know that it will change depending on where you clamp it. but if u clamped them further inboard wouldnt LESS of the original bar (the one actually working directly on the suspension) be stiffened by the secondary one?
    New Zealand
    ooh tricky.....
    yeah where you connect it to the car, longer arms = softer
    shorter arms = stiffer
    i dont see why the same wouldnt work for the second one
    please, no more PMs!
    Yeah, you need to think of it as a torsion bar, it's how far it twists along it's ...width, ie across the car. The ends that come forward (or backwards) don't actually contribute to the amount of body roll, they're the arms that apply the vertical force from the strut as a moment (twisting force) to the main part of the bar.
    Because of that, moving where that force acts (how far away) affects how far the bar twists. Same force further away creates greater moment (think breaker bar vs small socket) and twists bar further. More bar twist = more body roll = 'softer' roll bar.
    It shouldn't matter where you clamp the two bars together as the first bar transfers the force to the second bar around the common moment (balancing forces/moments about the twisting axis) so the force at the clamp changes with the moment arm (distance out from axis).
    Moment = force x distance; as you change the distance the force changes.
    Not sure i've explained it that well.
    Toymods Club Member
    Jun 2007
    ahh i think this is starting to make sense. so its sharing the load across both bars which halves the overall twist.
    would it bennefit from more clamps. i.e, in andrew_mx83's pic, one clamp either side of the bend on both sides, making it harder to twist because it has to twist 4 smaller sections?
    front suspension wise i picked up an MX73 front swaybar today, which is pretty fat i think it is 26mm and hopefully it will fit running MX62 LCA's and possibly MX62 or GE sigma castor rods.
    Jak
    10.74 @124 Mph
  1. Tacho tech
    By Hen in forum Tech and Conversions
    Last Post: 04-08-2009, 04:10 PM
  2. Which twin coils for 3T GTE ?
    Last Post: 26-07-2006, 10:43 PM
  3. html in the tech section
    Last Post: 28-12-2005, 10:49 PM
  4. Guidelines: Posting in Tech and Conversions
    Last Post: 20-09-2005, 04:42 PM
