Results 16 to 30 of 56
Thread: How to: Fit ST185 Coilovers to a ST165
    Default Re: How to: Fit ST185 Coilovers to a ST165
    just to throw a spanner in the works here josh...check out www.nengun.com
    they list Tien Superstreets for ST185 for $1295 + delivery...
    edit: just checked price delivered...and they are $1737 delivered to my door...which would be the same as your door id say seeing we live pretty close to each other...was that $1500 price including delivery?
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    GT4 Freak, and Conversion King Squid's Avatar
    MR 1JZ - yeah from experience the shelf price varies greatly store to store, but when you include delivery it always works out roughly the same...
    ST185 GrpA #116
    ST165 GT4 Project Car - Soon with v6 goodness.
    The glass is neither half empty nor half full, rather the glass is twice as big as it needs to be.
    i know this
    but nengun are generally the cheapest in the world for jap gear...didnt you say yours were $1900 delivered squid?
    Nearly a year ago tho, prices have dropped across the board...
    ST185 GrpA #116
    ahh fair enough
    Gravel Lover Backyard Mechanic stumpygt4's Avatar
    Hey squid, \the bolt you used, were they threded all the way or did they have a shank on them like the original ones. Just I am having a small problem finding bolts with a 45mm shank and enough thread for my DMS coil overs. They have camber washers either side which means the standard bolts are aobout 5mm short.
    Jeff Thomas
    TOYOTA TEAM CELICA
    1 x 1989 ST165 rally car, 1 x 1988 ST165 GT4 spare car & 1 ST185 khana cross car. (for now )
    1 x GT86
    Jeff - The bolts I used were about one thread too short, so some of the strut was overlapping the thread. When I switch to these 185 hubs, I will be using the standard 185 bolts.
    ST185 GrpA #116
    A real nowhere man Backyard Mechanic 88FOUR's Avatar
    is this a safe recipe?..
    St185 suspension , use the st185 front hubs (rears with bolt straight in) and theres your new suspension for the st165?.
    My Girl and my Four, nothing matters more,
    One of them is classy and the other one is raw.
    I have actually changed to that system now - I did so cos I got some 185 hubs already converted for 205 brakes... bt they do bolt up
    ST185 GrpA #116
    wa
    just checking. so the best way for coilovers at the front is to use st185hubs..? do the st162/5 axels slide straight in...? and all steering ball joints line up...?
    might as well use the st185 brakes etc as well yeh?
    Quote Originally Posted by jonathan yee View Post
    Can't speak for the 162 stuff lining up, but the 165 stuff does... if the 162 and 165 stuff is the same, then you can draw your conclusions from there.
    Yes if you have 185 brakes available too (and they are the twin pot one) I would suggest that you include them in the swap.
    I believe some early adm and some jdm models came with the single pot brakes, the same as the 165 ones...
    ST185 GrpA #116
    my st165 has twin pot calipers. The st162 hubs will fit, yet some have the camber adjustment, and others dont.
    I am about to do suspension work on the car, and have looked at the Tien Global web site... I have found the st185 ..(only do the street damper tiens).. and it says that they only suit RC models......
    whats your car squid,.. and what would these differences be....After new sub frame and bushings, I think Id have about 2500 to play with on the suspension.
    I am not sure I get your question mate - this one is about fitting the 185 coilovers to the 165.
    From memore the reason that tein list the models as only for the RC is that the electronic damper controls don't fit under the std bonnet. Without edc then it should be fine?
    ST185 GrpA #116
    Wll I ordered my teins from Perfect run just yesterday. .,.. am seeking out some front hubs and I alsohave a complete st185 rear cradle assembly..
    Thanks a lot for this thread squid without it I would have koni adjustables and kings using my own stutt towers cropped.... Great stuff.
  1. ST204 vs ST185 vs ST165 Front Brakes
    By arctophile in forum Tech and Conversions
    Last Post: 21-05-2006, 09:40 AM
  2. ST165 VS ST185 W2A intercoolers
    By sw20r in forum Tech and Conversions
    Last Post: 16-02-2006, 10:34 PM
