Results 46 to 60 of 72
Thread: BOV sizes
  1. #46
    Default Re: BOV sizes
    riiiiight.
    well, the turbosmart plumb back BOVs seem to be rather expensive. I'm willing to spend big dollars on a wastegate, but not on what is essentially a simple spring valve that doesn't have to be heat resistant or anyhting.
    Can anyone recommend a place to get a decent, cheap plumb back BOV from? 32+mm.
    Preferably as little bling as possible (which was the attraction of the turbosmart sleeper series)
  2. #47
    I hate to admit I have them bookmarked, but forums like Skylines Australia & Nissan Silvia Forums are great sources for cheap second hand bits & pieces like this.
    Then with a 5 dorra can of matt black spray paint you can stealth up your whole engine bay.
  3. #48
    Quote Originally Posted by JustCallMeFrank
    Loud in a charge air hitting the spinning compressor wheels way. It almost sounds like a venting BOV
    yup - I'm familiar with this noise.. its rather loud on my 7MGTE..
    I do worry about the consequences on my turbo considering its already been rebuilt and hi-flowed once ... don't want to have to do it again
    Quote Originally Posted by ndgcpr
    I think the 1G runs heaps rich on shifts when you add one though, i haven't really had any backfires though, so i am happy with the setup.
    But I do worry about this problem when I add a aftermarket BOV.
    I wonder which one is better to put up with??
    can I ask for pro's / con's / opinions ??
    Damo
    TRD83
  4. #49
    Quote Originally Posted by WA_TRD_83
    Since when did you remove your factory BOV?
  5. #50
    those forums seem to stock a lot of "FUKN-WHOOSH" BOVs - I'm very much after a plumb back, which are much harder to find
  6. #51
    Yeah true, but the for sale sections get heaps of traffic, so something decent should turn up soon.
  7. #52
    S.A
    This is one of the reasons people cite for using a BOV on a turbo engine, but the funny thing is you can't find anyone who's actually seen it happen. Keep in mind there are quite a lot of factory turbo engines with no BOV at all (1G-GTE, 3T-GTE, RB30ET) and they don't appear to suffer by its absence.
    It's a fallacy. All that happens is compressor surge, and that does nothing except make a funny noise. Manufacturers install BOV's to get rid of that funny noise, nothing more.
    ha ha ha Its no fallacy m8 its a FACT that has been proven and im sure if you do a search and read up on the info you will find this out.
    p.s if you think compressor surge is nothing but a funny noise you may want to check that one out 2
    in short compressor surge is caused by the turbo dropping off the left hand side of the compressor map . this is usually due to the turbo producing a volume of air greater than the engine can swallow
    Hey im no expert and will be the first to admit it when im wrong but i have been a mechanic for 8 years and have worked reconditioning turbos for 2 of them years.
    The reason why there are alot of factory turbos without BOV is because they run bost levels of 5 -9 psi where causing damage is almost impossible. I would love to see a car run 20+ psi without one.
  8. #53
    S.A
    Quote Originally Posted by Sir_2jza70
    Pft, you cant be serious?!? Are we talking about paper mache ICs here or what??
    Im totally serious!
    Extreme cases though 40 - 50 psi drag cars
  9. #54
    I would be very concerned about the quality of an IC that fell apart from anything to do with 50psi
  10. #55
    Quote Originally Posted by 30psi 4agte
    I've done plenty of reading don't you worry. If you have any sources of information (not opinions) which supports your theory I'd certainly like to see it though.
  11. #56
    factory BOV is still there.. doesn't seem to be doing much tho..
    not sure what boost I'm running.. I really should connect my boost gauge up..
    Damo
  12. #57
    more qualifications than I have.!
  13. #58
    Ghetto Goodness Automotive Encyclopaedia Ghetto-AW11's Avatar
    Draven just get a nice big turbosmart plumback in sleeper series black. It might cost some money, but atleast you get it right away and it works well.
    Homebrew, triumph triple, turbo aw11
  14. #59
    a mate at turboXS is (hopefully) getting me a plumb-back from there. I refuse to pay ~$300 for a plumb back
  15. #60
    when you see one in real life... they are FSCKING HUGE. Like 4times bigger than the average bov.
  1. 3sge - bearing sizes aftermarket/toyota oem ??
    Last Post: 13-07-2006, 12:53 PM
  2. BOV on a Diesel ??
    By 1200det in forum Tech and Conversions
    Last Post: 03-07-2006, 05:26 AM
  3. 1ggte bov
    By love ke70 in forum Tech and Conversions
    Last Post: 22-02-2006, 08:32 AM
