jsut to clarify a few things.
Draven dont go bosch --- I know you wouldmt any way but you should see what anything over 20 psi does to em. !!!
In the early dAys when i ran two of em i ended pushing the valvw through its seat and out the outlet pipe. If ya think that is amusing should have seen the look on the guys face when took it back for warranty !![]()
secondly a blow off valve is best positioned as close as possible to the throttle body because:
When the throttle closes a large amount of pressurised rushing air is heading towards a dead end. This inturn causes a reversion pressure wave back in the oposite direction ( towards the turbo )
This pressure can cause the compressor to slow so rapidly that its fins can be bent !!
In extreme cases the wave has split intercoolers apart !! with the two waves colliding.
The blow off valve is positioned closest to the throttle so that the pressure wave has the shortest possible path to exit.
Modern cars running more boost and with an intercooler (more volume in the inlet system) would make even more noise without a BOV.
