Results 16 to 21 of 21
Thread: TA22 18rg conversion carbie issues
    Default Re: TA22 18rg conversion carbie issues
    Quote Originally Posted by gearb0x
    One thing that really helped on my 2TG, rather than rebuilding, we pulled the top off the carbs, pulled every jet visible out and dissassembled them, blew them out and re assembled.
    If your carefull you wont need to replace any of the gaskets.
    A rebuild will have the same effect, but my 2TG seems to be needing the jets blown out every few months as it spends most of its time on dirt
    Phill
    Thanks mate!
    Quote Originally Posted by MAD79R
    get the carbs rebuilt and someone who knows what they are doing to tune them properly you will notice the huge difference when tuned .i did this when i did my conversion but i have 40mm webers. dont go to ultra tune again i also replaced mechanical fuel pump with electric pump Steve
    I'm in the sth shire in sydney, any suggestions where I go for a carby rebuild kit and electric fuel pump?
    ultratune *pfftt* i'm not going back there again.. been there twice, two different places and have nothing good to say about them..
    Junior Member 1st year Apprentice rabbits's Avatar
    Aug 2006
    Hey there is a place called MAXI SERVIVE CENTRE the carburettor factory they do and sell everything the main guy is excellent his name is Nick Shumak they are located at 103 Beauchamp Rd Matraville ph:96957911 or 96957922 they do spare parts , carbi's ,injection give them a try.
    Junior Member Domestic Engineer TA22 GT's Avatar
    Yep, Solexs are great if tuned properly.
    I spent the cash to get them tuned properly and after that they were perfect until I sold the car around 10 years later....
    As for your problem, take the top cap off and check the jets are tight. This is the only problem I ever had. Every now and then a jet would work loose slightly and would cause the problem you describe.
    The first time it happened I tried all sorts of things cause it felt like missing under laod, eg maybe spark etc. But in the end it was only a loose jet.
    Best thing is it only takes 2 mins to fix. I assume the 18RG solexs have the same top cover held by one screw, under there you will see what I'm talking about.
    Hope this helps,
    Simon
    Quote Originally Posted by TA22 GT
    Yep, they do.
    seeyuzz
    river
  1. Engine conversion for ta22 celica
    By jp_ta22 in forum Tech and Conversions
    Last Post: 03-08-2006, 11:03 PM
  2. Building an Australian RA21 (18RG + TA22)
    By ace in forum Tech and Conversions
    Last Post: 04-07-2006, 09:09 AM
  3. 18RG to ????? Conversion
    By Silly Rabbit in forum Tech and Conversions
    Last Post: 05-04-2006, 11:09 AM
  4. 18rg into ta22 crossmember?
    By magicmitch in forum Tech and Conversions
    Last Post: 31-01-2006, 11:26 PM
