Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Thread: Interesting Bush Info - Nolothane vs Polyeurethane
    Default Interesting Bush Info - Nolothane vs Polyeurethane
    Hey guys. Thought id share some interesting info i found out today. Is regarding aftermarket bushes.
    I was talking to someone in suspension with regards to which is better when talking about materials - nolothane or polyeurethane.
    He discussed with me that they are both the same in the making process, ie mould is poured etc etc, however the polyeurethane is then cured in an oven. The nolothane is left to dry in open space.
    He explained this difference will cause the nolothane to literally disintegrate into dust over time where wear happens. Like for example a trailing arm bush, or a swaybar bush where a metal sleeve runs through the bush...the nolothane wears away over time, whereas the ployeurethane keeps together...
    Just thought id let yous know
    Blake
    Default Re: Interesting Bush Info - Nolothane vs Polyeurethane
    Thats great, exept they both get wear so have to be changed anyway! that would be great if there was never any load put agaist the bush, but that dosnt happen with cars!
    Be great info for someone that only drives there car a few thousand km a year and in 5-10 years they wont have to replace them.
    Quote Originally Posted by kingmick
    like me....dubbo and back probly takes 1/3 of my years total
    tasmania
    what's that pineapple stuff called? that's stiffer than polyurethane isn't it? do they make normal bushes out of it, or just those diff cradle bushes?
    beer me!
    Quote Originally Posted by joecoolmk2
    pineapple stuff? lol
    tasmania
    yellow semi-transparent stuff that they make pineapple slice shaped diff cradle bushes out of then!
    beer me!
    hmm weird. The ones they supplied me for the diff cradle were this polyeurethane too!
    tasmania
    so it is polyurethane then ok
    just different grade
    beer me!
    guess so? they gave it to me for the diff cradle and the rear xmember, so its obviously heavy duty shit!
    tasmania
    it's supposed to stiffen up the rear, to stop the cradle moving around so much when you're trying to drift
    beer me!
    Like most drift things, its a total wank. Might help when your drifting with shit springs and shocks, but with decent shocks they do the work, not some piece of synthetic rubber!
    tasmania
    plastic actually.
    beer me!
    Yes but to people with feeling in there hands what does it feel more like? hahahahah
    plastic...hgahahahah had to say it
    tasmania
    i just googled it, and it's neither plastic nor rubber, it's in between.
    pretty versatile stuff actually.
    http://www.sdplastics.com/polyuret.html
    beer me!
  1. Castor Rod Bush Replacement on MX83
    Last Post: 23-11-2016, 03:41 AM
