Results 1 to 15 of 18
Thread: auto and manual bolt ups
    Aug 2006
    Default auto and manual bolt ups
    im swopping my 22r for a 22re in my land cruiser bundy, ive found a donor car, but it is an auto box. can it still bolt straight on to my manual box, or is there other things to consider? and what are they?
    Default Re: auto and manual bolt ups
    Will bolt up fine, as long as u have all the parts from ur 22r-W58, ie clutch ass and bell housing...
    Aug 2006
    Its actually going into a G52 Box, should be the same, as i do have all the clutch etc from my car???
    All R series engines have the same bellhousing bolt pattern, so you'll be fine.
    any difference in engine plates? (between box and engine?)
    As already said above me. Remember you'll need to put a spigot bearing in since the engine used to have an auto behind it! Not something you want to forget.
    Junior Member Backyard Mechanic jonra23's Avatar
    Jun 2006
    Main thing will be the wiring to run EFI system, the actual motor is exactly the same as others have said.
    regards
    jon
    Aug 2006
    Cheers for the responce guys.
    This spigot bearing that was mentioned, is it something a first timer will figure out, or is it best to take it to a professional to sort out?
    Jun 2006
    Teh spigot bearing is the bearing in the back of the cranckshaft of teh engine that the input shaft of the gearbox is supported by.
    It is just a matter of tapping the bearing into the back of the crank, don't bother trying to get the old one out of your current engine, they are pretty cheap.
    regards
    jon
    Aug 2006
    Sounds easy enough, thanks.
    Is there anything else to look out for?
    you realise you have to install an efi high pressure fuel pump now?
    is the motor purely a replacement for a bung one? You can swap the manifolds and stuff over so you can reuse the carby stuff if that is easier. Otherwise, have fun with the wiring
    Aug 2006
    My whole engines going, it blows smoke, has no power and i go through about 3Liters of oil every 550km!!!!! plus its running a webber of a cortina, which cuts of when i go up big hills in 4WD
    I figured an efi would be a better option for the money, so i thought of buying a whole celica or corona with a 22re, that way i should have all or most of the parts i need.
    Should that efi high pressure fuel pump be in the donor car???
    (If you havent noticed, my mechanical knowledge is limited, and yes it is gonna be a mission, hopefully not to expensive)
    Thanks for all your help guys
    Jun 2006
    If you are getting a donor car you will have everything you need, yes it will have the fuel pump, make sure you replace the fuel hoses with EFI quality hose.
    If the model cruiser that you are playing with came out with EFI may be easier to try and get an EFI tank or see if a Landcruiser EFI pump will fit in your tank rather than trying to rig up a non standard pump in your tank.
    Hardest bit is going to be the wiring, makes sure you get a full wiring diagram for the donor car and the Land cruiser.
    regards
    jon
    Aug 2006
    EFI quality hoses!!! i didnt know that one, ill check that out
    No, unfortunatelly the Bunderas only came out in carby or diesel!!!! wish they did tho, probably wouldnt be having all these headaches right now.
    ahhh the EFI pump, another thing to research,
    I actually have the wiring diagrams for the bundy and coronas, but at the moment the donor car is looking to be a celica, can anyone help with that diagram???
  1. 1jz manual conversion...auto computer?
    By chicane ma71jz in forum Tech and Conversions
    Last Post: 06-08-2006, 07:14 PM
  2. jzz30 auto to manual conversion
    By RIPSIP in forum Engine & Driveline Conversions
    Last Post: 08-06-2006, 06:08 PM
  3. MZ20 / MA70 Auto - Manual conversion
    By Disturbed1 in forum Tech and Conversions
    Last Post: 12-04-2006, 07:49 PM
  4. 1GEU > MTEU + Auto > Manual in GA61 swap
    By KwS in forum Tech and Conversions
    Last Post: 06-12-2005, 01:36 PM
