Results 31 to 45 of 46
Thread: X2 excel radiator
    Default Re: X2 excel radiator
    x1 top mounts are bolt on so worse case your looking at drilling new holes in your support and dropping a nut on bolt through to fix the mounts.
    Black Betty >HERE!<
    (\__/)
    What ^ he said is true.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    right angle at the top ... right angle at the bottom ... tapped a thread into the top and bolted on the mounts. Drilled holes in the bottom angle for the lugs to sit in ... eventually a few rubber spacers - washers will go between the angle and base of the radiator.
    Black Betty >HERE!<
    (\__/)
    I spent 2.5 hours walking all over pickies today in the hunt for the "perfect" rad upgrade for the RA28.
    I settled on the Excel Rad too ! everything else that got me excited was to high or too wide
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Traditionalist Domestic Engineer parrot's Avatar
    I have just come in from welding on new support lugs for my V6 camry twin core which fits a treat in an AE86. If you look at ST162's or AE82's and undoubtedly others, the drivers side support lug is a bolt on rather than welded. Makes them easy to get off at pick a part. Make sure you take the rubbers too as they are a different outside dimension (bigger) although the inner hole is the same size as an AE86. When fitting the camry rad to an AE86, the new brackets go on just inside the original AE86 mounts so you can leave the original AE86 mounts in place in case you ever need to go back for some reason. Plus the V6 camry rad is exactly the same height as an AE86 rad, just a bit wider. In an update to my earlier thread, the wiring loom does actually still fit in the original location. The only issue is that the top hose outlet is 34mm instead of 31mm, which isn't much of an issue, and 30mm over to the drivers side.
    Don't know if I updated this but I have the x2 radiator in now. On my drive to Jamboree (2 hours in 30deg heat) the car never went about 86deg on the highway. Does the job for me
    QUICKEST 1JZ'S IN OZ
    I was checking the guage at the khana yesterday, didn't twitch.
  8. #38
    30 deg eastern creek track day temps never got over 95
  9. #39
    Guys,
    On this note, are you using the factory thermo fans for the excel x1/x2/x3 radiators?
    I have an X3 radiator for my TA22 and need to buy thermo fans yet... Not sure if I go 1 aftermarket, or buy the stock thermos new/used
    Rob
  10. #40
    Im using the factory thermo.. This was one of the big selling points for me was that the Excel radiator already has the mounts for the fan.
    Unlike the factory radiators in my AE86 & RA28 you have to make brackets or put bolts through the core etc.
    Makes for nice & neat install.
  11. #41
    after market for me. 2 x 10" $50 ones that were at SuperCrap Auto.
    relays and all included ... just gotta get me a tridon thermo switch.
    Black Betty >HERE!<
    (\__/)
  12. #42
    I have a different thermo. It was already mounted from my old radiator so I just used that.
  13. #43
    Interesting, I might get a quote from Hyundai or look around at wreckers for stockies...
    I have a 14inch thermo which is around 30mm shy of fitting it unfortunatly, but as you fellas mentioned the standard mounts are def a bonus and would look neater!!
    Thanks again,
    Rob
  14. #44
    Ive actually got one of the standard fans (the smaller depth one) mounted on the front of the rad (there aint no room on the back at all)
  15. #45
    ive got the x2 in a sprinter 4agte, works a treat so far. stock thermo fan fits and looks nice and neat, i might fit the second fan (i think in an excel its activated when the aircon is on) just for peace of mind!
  1. RA23/28 radiator upgrade
    Last Post: 24-07-2006, 10:24 AM
  2. Overheating ta22
    By 74sLeeka in forum Tech and Conversions
    Last Post: 29-06-2006, 07:47 PM
  3. Cooling Systems - Overheating Problems.
    Last Post: 24-06-2006, 09:40 PM
  4. Radiator question.. Core thickness/air flow
    Last Post: 05-05-2006, 09:49 PM
  5. Welds onto a radiator
    By Biggo in forum Tech and Conversions
    Last Post: 27-02-2006, 05:20 PM
