The FPC (fuel pump controller) pin on the jzx90 ecu switches to ground when the ecu needs the fuel pump to start. So wire this pin to a relay to turn on the fuel pump and you'll be sweet as brudda.
You could probably wire it to the stock mx83 fuel pump relay if you wanted to keep the wiring clean.
