Results 16 to 23 of 23
Thread: 4AGE Porting - OST-032: Skippy gets a head
    Melbourne Victoria
    Default Re: 4AGE Porting - OST-032: Skippy gets a head
    thats why you start with 4 different heads and check it for core shift ,even the altezza 3sge has the same problem
    Why am i always a.. Domestic Engineer RAAAH23's Avatar
    Jul 2009
    New South Wales
    Great work but why can't you get new valves all round?
    Cheers, Alex
    - 1976 TA23 2T-GTE GT3076 ID1000cc E85 Haltech PS1000, W58, G Series Diff, B45 Simmons
    oregon
    Quote Originally Posted by RAAAH23 View Post
    I can.... but I sense you meant something else....????
    oregon
    4th gear pull, #s are @ the wheels
    Details of Skippy's build: 7 rib none squirter block, 40mm rod journal crank, 40/18 rods modified to take a press fit 20mm wrist pin, 81.5mm aftermarket 10.3 to one pistons, new Toyota rod bolts/nuts, Cometic .036" head gasket, stock 87 and earlier cams, new Toyota (OST ported) oil pump, AEM adjustable timing pulleys, and an OST ported largeport head with a Loynings valve job... All Toyota gaskets except Cometic .036" head gasket
    Jul 2007
    is this thing still running the factory intake with TVIS?
    oregon
    yes.... you can see TVIS bump @ 4500. management is stock AE82 "FX16"
    torque jumps nearly immediately to 90+ #/ft, and at 26-27 seconds TVIS kicks in and you can see the torque jump to 108#s (hp on left, torque on right)
    http://ost.ebeans.ch/albums/userpics...dyno_120hp.mp4
    Jul 2007
    The torque hump is why i asked
    Jun 2010
    queensland
    Love reading this thread, very good!
    1977 280se S class - Oliveoyl (Built 6.9 dry sump in the build)
    2005 GL500 "Landcruiser With AMG power"
    2004 Supra JZA80 3.4l 4088r e85 cage 675rwhp 26psi
    2005 E55 AMG silencer delete, carbon lip, carbon mirrors, carllsson lowering arms
    1998 C200 + 2JZGTE - (Tried to kill me now gone)
  1. 4AG head porting - OST-031: A delicate dance
    By oldeskewltoy in forum Tech and Conversions
    Last Post: 21-05-2015, 03:41 AM
  2. 4AF head prep and porting
    Last Post: 23-03-2011, 06:35 AM
  3. 1uz CNC Head Porting - PICS!
    Last Post: 29-06-2009, 04:53 PM
  4. Where to go for Head Porting ?
    By abently in forum Tech and Conversions
    Last Post: 23-07-2007, 09:26 PM
  5. 22RE head porting?
    By Hibino in forum Tech and Conversions
    Last Post: 21-11-2006, 10:48 AM
