Results 1 to 5 of 5
Thread: 4ac head - how much can be safely removed??
    Default 4ac head - how much can be safely removed??
    Howdy guys
    I am restoring an ae71 rally project, and the head is at the shop getting the cam done and port matching for the weber, they have asked me if i want to take any material off the head to raise compression slightly
    but he only has the head and doesnt know how much can safely be removed?
    it is a fair drive to take the whole engine their, so I was wondering if anyone knew?
    Thanks in advance
    David
    Cusco camber tops available for all early mac strut
    loves hi RPMS Backyard Mechanic
    Default Re: 4ac head - how much can be safely removed??
    Will you be taking any material off the block or decking the block at all?
    N/A for life...
    Jan 2012
    Finland
    1,5 mm or even 2 mm can be skimmed safely.And don't worry cam being retarded;it's only better that way.
    block will be left as standard for now
    Quote Originally Posted by MorGo View Post
    thanks for that mate, will put it to him
    have you done that yourself?
    David
    pretty much what i was gonna say
    N/A for life...
  1. How much boost can the M-TEU handle safely?
    By Seth in forum Tech and Conversions
    Last Post: 28-04-2011, 09:58 PM
  2. What boost can i safely run thru a 7mgte
    By sumfancyname in forum Tech and Conversions
    Last Post: 28-02-2011, 08:39 AM
  3. Should I clean the tops of the pistons while head is removed?
    By DrNick in forum Tech and Conversions
    Last Post: 19-11-2009, 01:33 PM
  4. 4 Rib Belt where a 5 Rib should be..Can it be done safely?
    By craigy in forum Tech and Conversions
    Last Post: 03-08-2006, 10:00 AM
