Results 1 to 14 of 14
Thread: What boost can i safely run thru a 7mgte
    Jun 2010
    Talking What boost can i safely run thru a 7mgte
    HEY guys i have just bought another ma61 but this one is a 7mgte (my 1st turboed car since im on my greens ) and its got a boost controller on it but its pretty shit cause it keeps boost spiking up to 15psi. apperently they come out standard with 7psi and the guy i bought it of said its at 9psi at the moment which is good but when it spikes to 15psi it hurts my neck and thats how good i want it to go lol. so im wondering what i can saftly run thru it
    STEER WITH THE REAR
    Jun 2010
    Default Re: What boost can i safely run thru a 7mgte
    i shld also mention it has a big intercooler hanging on the front and its 3 inch from turbo back .double post
    STEER WITH THE REAR
    Aug 2009
    stock turbo? usually the turbo can run 14psi max anything over is pushing the turbo.
    but id probably want to run safc, and bigger injectors atleast
    May 2007
    safely on a 7m is a funny combination of words...
    if its spiking from "9psi that is claimed" to 15psi then thats a problem
    you need to fix that before considering raising the boost otherwise it will spike from 15 to god knows what
    without a fuel computer raising the boost without checking AFRs is a recipie for disaster...
    Act
    yeah I would stay around the 10 -12 mark without doing the Lexus afm mode and bigger injectors.
    However as above sort the spikes out first
    11psi is the boost cut on stock ECU is it not? Not sure how it could be spiking to 15psi unless its got some mods.
    What is the history of the motor, head done recently? mhg? If it was me id get it to stop spiking and leave it at 9psi if the motor is of unknown history.
    RA23 - Twincharged
    JZZ20 - Daily
    Act
    I ran 10 pound on the old turbo/motor and had no issues.
    Also as Kedderz said watch that BHG
    Oct 2008
    TAS
    10s the magic number with a 7, unless your doing more mods, as Kedderz said, it 'should' cut at 11 anyway.
    1983 Toyota Celica Supra
    Jun 2010
    well im not 100% with the history as i haven't built it all ino its got a metal head gasket, hks fuel management system, rebuilt turbo, intercooler, and thats all i no of i think.well the T peice looks hand made lol so il go buy a newby and put it to 10psi and that sounds like a safe number.i defiantly no its spiking to 15 unless the guage is wrong or it cld even have a after market computer or something???? who knows
    STEER WITH THE REAR
    what is this "hks fuel management system"?
    RA23 - Twincharged
    JZZ20 - Daily
    Jun 2010
    dnt no its in the glove box.thats wat is written on it.u can turn the fuel up when u turn the boost up.as i said im a noob to turbos lol
    STEER WITH THE REAR
    got a pic of it?
    RA23 - Twincharged
    JZZ20 - Daily
    Apr 2008
    im runnign 12 atm and about to bump it up 2 15... standard bottom end (rebuilt 5year ago) aftermarket ecu, hi-flowed turbo...going external gate
    Canada
    I would suggest reading up on it.
    (And leaving the boost turned down until you do)
    There are many variables.
    "Maximum Boost" by Corky Bell is a good option.
    http://www.amazon.com/Maximum-Boost-.../dp/0837601606
  1. My high compression + boost concept
    Last Post: 18-06-2012, 09:40 PM
  2. boost problems
    Last Post: 14-03-2009, 04:24 PM
  3. 2jzgte - strange surging boost when cold
    By PlacentaJuan in forum Tech and Conversions
    Last Post: 15-04-2008, 10:56 AM
  4. Autronic SMC boost control help
    Last Post: 27-08-2006, 10:16 PM
