Results 1 to 7 of 7
Thread: 4AGE main bearing clearance
    Oct 2009
    Default 4AGE main bearing clearance
    Putting my 4A smallport together, getting 0.075mm on the mains.... its under the limit of 0.1mm but was hoping it would be closer to the std clearance.
    Run with it or get the crank cut undersize?
    Default Re: 4AGE main bearing clearance
    on all 5 of the mains?
    Aug 2013
    Quebec, Canada
    That's a bit looser than what I'd like. Rod would've been fine but on the main I'd be affraid about oil volume/pressure going to the rods. I'd personnally get a crank grind and use undersize bearing.
    KE20 1974 <- Sold -> Thread
    AE95 1990 <- 4A-GZE daily driven wagon...
    Oct 2009
    Quote Originally Posted by Sam_Q View Post
    1 is a little tighter, closer to 0.05
    Other option is to go with the tightest Toyota bearings, I'm using ACL race atm but dont know their size aside from std. Block is stamped for 2's
    Oct 2009
    I've run the numbers on the block and crank;
    Block - 23232
    Crank - 01111
    Shells = 24343
    Explains why my no1 looks a tad tighter compared to the rest;
    Perhaps my best bet is to buy all 5's and see how they size up, the difference between the smallest and largest bearings is 0.012 (no1 are 2.002mm vs no5 which are 2.014).
    I've got no idea what the ACL ones are....... but I think they are 2.001mm
    Oct 2009
    Err looks like ACL do 0.025 oversize bearings....... perfect for linished cranks I think
    Junior Member Conversion King
    May 2010
    Definitely good stuff to hear, keep any info you find coming, as this is relevant to my interests.
  1. 4AGE main bearing cap failure - billet option
    By toddw in forum Tech and Conversions
    Last Post: 18-02-2011, 12:09 AM
  2. 4ag Main Bearing stamp
    By old_mr2 in forum Tech and Conversions
    Last Post: 05-10-2010, 03:45 PM
  3. 4age 100kw rebuild - main bearing clearance
    By Grega in forum Tech and Conversions
    Last Post: 02-12-2009, 10:24 AM
  4. 7mgte Main Bearing Question
    Last Post: 08-11-2007, 03:18 PM
  5. 3S-GE GOING Main bearing....?
    By blah_00 in forum Tech and Conversions
    Last Post: 14-11-2006, 02:12 AM
