Results 1 to 4 of 4
Thread: 4age 100kw rebuild - main bearing clearance
    Hoppers Crossing
    Default 4age 100kw rebuild - main bearing clearance
    Hi
    for those more educated than i am (with practical knowledge if possible), i'm rebuilding my 100kw motor.
    i had my crank ground 10 thou on the mains and big ends as they were no good and the crank had the slightest 'bend' in it. the rod ends were resized and with the new bearing shells come in perfectly all at 0.051mm. lovely
    my mains are another story, with the new 10thou shells,
    1,2,4,5 are all 0.076mm
    3 is 0.051mm
    my book tells me the following
    U/S 0.25mm (10thou) 0.013mm - 0.053mm should be the standard oil clearance
    max oil clearance is 0.10mm, so at 0.076 i'm in tolerance.
    remembering that 3 also has duties of thrust it has less clearance than 1,2,4 and 5
    would this pose me any problems and is this acceptable given i'm within tolerances. for the life of me i can't find my other clearances when i built my last sweety 4age
    comments/flames/thoughts all listened to.
    perth
    Default Re: 4age 100kw rebuild - main bearing clearance
    have you measured the crank or swaped bearings around ?
    if its within tolerance it should be fine, but it would be nice to find out why its out. (you do get the odd one out everynow and then) if you cant find a prob, measure the crank maybe you can play with that.
    Hoppers Crossing
    no - that i havent done.
    its well within tolerance so theres no issue, but, that #3 main with the 0.051 is interesting.
    the only thing i'm thinking is that the #3 tunnel is possibly a little tight over 1,2,4,5 - it wasn't resized (my rods were and they are absolutely perfect)
    waiting to speak to machinist.
    perth
    ahh k, i thiught you had it tunneled aswell. well measure them up and see what you get.
    i usually do it all when i build a problem engine (like your bent crank) re-size rods, tunnel bore mains and measue/grind/linish crank.
  1. DIY: Transmission Rebuild *** No 56k ***
    By assassin10000 in forum Tech and Conversions
    Last Post: 30-05-2007, 12:07 AM
  2. 4AGE 100kw smallport turbo rebuild
    By BoostBoy in forum Tech and Conversions
    Last Post: 07-05-2007, 10:24 PM
  3. Cut and shut 4age clearance issues??
    By RZA12 in forum Tech and Conversions
    Last Post: 27-03-2007, 09:30 PM
  4. 3S-GE GOING Main bearing....?
    By blah_00 in forum Tech and Conversions
    Last Post: 14-11-2006, 01:12 AM
