Results 16 to 27 of 27
Thread: Turbo Choice for single on Gen 3 1GGTE - TD05 18g/Td06 18G etc
    Junior Member Conversion King
    May 2010
    Default Re: Turbo Choice for single on Gen 3 1GGTE - TD05 18g/Td06 18G etc
    TD05-19T twinscroll would be better power wise than a VF36, but no idea when it comes to spool etc.
    Nov 2009
    I was thinking something like this
    http://www.ebay.com.au/itm/Kinugawa-...item3f2a67cdea
    Doesn't say if the HP is at the wheels or engine, I guess they would be talking about at the wheels.
    Junior Member Backyard Mechanic scottreichstein's Avatar
    Aug 2011
    my 10c
    ive got a t25/t28 hybrid on my 1g and run 14psi for now boost comes on around 4000rpm which prob would suit your what your after and I was running a dodgy y piece
    RIP st141 died doing what it loved http://www.facebook.com/media/set/?s...type=3&theater
    1ggte hilux massive 143rwkw http://www.toymods.org.au/forums/sho...724&highlight=
    corolla sportivo daily LIFT
    Wgtn
    Quote Originally Posted by eightsixboy View Post
    My 2c, it's a bit big, a TD-06 Turbine wheel isn't a small thing to spool up on a 2.0l
    More suited to a +2.5l (like an EJ25 subie mota).
    Those turbine housings make it so easy to make a nice Y-pipe.
    This one has the TD-05H Turbine which would be better suited to a 2.0l
    Kinugawa TD05H - 18G SUBARU Twin Scroll Turbocharger
    Nov 2009
    Quote Originally Posted by e30-323ti View Post
    That looks like a very good option, I think your right with the TD06 wheel, prob not needed for my application/power.
    Im going to get my car dyno'd soon so that should help me determine what power level I go for. If I only have 160ish atmo then getting over 200rwkw will be plenty.
    I'm using the turbo in the pic below, it's a garret GT 3076R, twin entry, with a .8 rear housing
    I'm making around 350hp at the wheels on around 21psi boost.
    cheers steve,
    1ggte, 11.22 @122mph
    Works quite well, manifold i'm using, is just a HKS cast manifold, which is also split entry.
    Been running this combo for a good 5 to 6 years now, with great reliability.
    It all equates to an 11.22 ET and 122MPH, on a really simple setup, which is around 260kw at the wheels.
    cheers steve,
    depends what your after. i just finished my single conversion on a 1ggte and used a gtx2867. i love the extra responce on the street and im getting possitive manifold pressure at 2000 rpm. im only talking 3 or 4 psi put that makes a big differance. that turbo will run as much boost as you want but in a street car i like boost as low in the rpm range as possible i rearly take mine over 6000 on the street and will prob never see the strip. if you want the most hp and best 1/4 mile get a big turbo. if you want a street car have a hard think about something 28 based. its only a 2L remember.
    RA28 1G-GTE
    Nov 2009
    Did you end up getting a full tune and dyno'd mike?
    Im getting my car dyno'd tomorrow night so should be interesting to see what power its making at the moment.
    You would quite surprised on how street able mine actually is, most peoples impressions is it would be a laggy pig to drive, but its not necessarily the case.
    How did your tune go?????
    cheers steve,
    i actually dont have a peak hp figgure..... i told the tuner i didnt care about peak hp and all i wanted was the fattest midrange possible. Im heading back out there next week so ill ask for a printout if they have it on file. he did say that when we played around with cam gears to fatten up the bottom i would loose 15-20 kw at the top but that didnt bother me. id say i have 205 or 210 rwkw but who knows. it's a little old car running a little over 20psi threw a little turbo on a strait 6 with an LSD.....
    RA28 1G-GTE
    Nov 2009
    I'd be very happy with 210rwkw.
    Didnt end up getting mine dyno'd due to pinging issues. Looks like full standalone before i go single now.
  1. Converting 1GGTE from Twin Turbo to Single Turbo
    By 1GSupramanGTE in forum Tech and Conversions
    Last Post: 10-04-2012, 12:10 AM
  2. 1ggte:TD05 vs T3/T4
    By gttwinturbo in forum Tech and Conversions
    Last Post: 07-03-2009, 08:29 PM
  3. 1G- GTE TD05-16G Single Turbo Upgrade
    By zolpix in forum Tech and Conversions
    Last Post: 23-01-2009, 01:07 AM
