unless you have a trigger wheel of some kind, you will need to use the VR (variable reluctor) sensor in the dissy.
The MS2 files i will be sending you tomorrow are for my 18RGE, 9.7:1 pistons, 22853 head, otherwise stock rebuilt motor.
You will need to get the dissy mechanical advance "locked" (ie, welded) so that there is no mechanical advance from the distributor, hence providing the MS2 with a stable fixed engine position signal. I found that i did have some issues with random "spaz-out" events with my ms2, whereby occasionally under full WOT, above 4000rpm it would haev these brain farts and all the signals would go spastic and the engine missed a couple of beats. I never managed to iron that out..... it shit me to tears though..
Also, my tune had an AFR target table, using a wideband O2 sensor.... so you will need to probably reconfigure it all.
The ignition map and fuel map are probably pretty good though. If you have lower comp pistons you may need a bit more fuel and a little more advance.
Also, i never got the acceleration enrichment sorted out. I could just never get it right.....
