Page 17 of 43 FirstFirst ... 7151617181927 ... LastLast
Results 241 to 255 of 634
Thread: Megasquirt users thread to discuss all things Squirty
  1. #241
    Default Re: Megasquirt users thread to discuss all things Squirty
    can't you use it with no serial?
    can't afford TS licence = can't afford fuel to run the engine with?
  2. #242
    Feb 2010
    lol maybe i should have said "cheap" not poor. Yeh you can use it without the key, but its pretty limited kinda. Ill buy one, just thought id throw it out there since i couldnt find a crack etc anywhere :/ man im tight
  3. #243
    Hey Knightrous, Are you getting a reliable signal at very low rpm? ie under 100rpm?
  4. #244
    Jun 2010
    is anyone running a megasquirt on a silvertop 20v
  5. #245
    Feb 2010
    Quote Originally Posted by phil-ma70 View Post
    ye knightrous is lol
  6. #246
    Feb 2010
    People should give me some rep so i can start selling stuff and earn enough to buy Tunerstudio
  7. #247
    Jul 2009
    Quote Originally Posted by old_mr2 View Post
    I've only spun it over with the starter, which was running between 150-200RPM with my shit battery.
  8. #248
    Feb 2010
    Yeh you need to be careful (as knightrous knows) with the nippon denso CAS VR pickups, the settings on the variable resistors on the mainboard need to be all the way to min, or sometimes you need to remove them and actually use a jumper or set resistance for them if you have issues.
  9. #249
    Quote Originally Posted by knightrous View Post
    Were you getting a solid cranking signal? This is what I couldnt get. Hopefully the resistor will sort this.
  10. #250
    Jul 2009
    My battery is le sad
  11. #251
    New Zealand
    Just picked up a Ford EDIS setup to go with the MS-II, bye bye dizzy and hello wasted spark.
    Since I got the V3.57 MS-II it is just a matter of swapping some jumpers to run the EDIS gear. Now I just need a 36-1 trigger wheel to fit a K series and to cut down a dizzy to act as the oil pump drive. Going to mount the coil above the dizzy so it still looks semi factory.
    Callum
  12. #252
    Feb 2010
    Jakarta
    Good luck on the EDIS conversion! Successfully done it myself. PIP and SAW line aren't shielded on mine so maybe you could save a few bucks on normal wire there.
    Anyone know if GM's ESC module works with Toyota Knock Sensors? I'm thinking that all knock sensors are just the same piezoelectric stuff internaly, so it should work?
  13. #253
    Feb 2010
    nice work man! good luck with it!
  14. #254
    Hi Knightrous,
    I added the 51k resistor to R21, but still getting a strange signal, cant get solid cranking signal and erratic rpms.
    Can you please share your Trigger settings etc? Also you wiring for VR+ VR- and VR2 ..Cheers Mate.
  15. #255
    Jul 2009
    Can do Old, just need to get my tuning laptop into the house one night and will post up the settings.
  1. Overboost caused by plumb-back BOV wrong way round! Discuss...
    By Stefan in forum Tech and Conversions
    Last Post: 03-09-2008, 03:39 PM
