Results 1 to 14 of 14
Thread: 22re water in oil
    Nov 2008
    Default 22re water in oil
    After finding water in the oil a month or so ago a crack in the head was found. Got that fixed, decked the head, new head gasket. While I was at it I got an engbldr cam new timing chain and guide rails and had the injectors cleaned which, apparently, needed doing REAL bad. Put the motor back together and apart from a couple of external water leaks and having two bolts left over everything appears to be fine, except, water in the oil again. Milky water.
    When I put the oil in the engine, there was no sign of any milkiness. Nice clean oil on the dipstick. It was only after I ran it for 5 minutes with the tappets howling that I decided to redo the tappets straight away. When I took the rocker cover off the oil looked like milk. Simple as that. Very disappointing.
    Any suggestions as to what could be causing this ?
    Trevor
    south austraila
    Default Re: 22re water in oil
    Hmmmmm..... 22R iced coffee machine..
    yep this is a common prob' with the single row timing chains..
    PM sent.. with phone number.. & "yes" .. it is best to ring me on this one..
    as it is to hard to explain..
    Note:- limit time factor for the offer to ring me..
    i don't get to these theads oftern any more.. & have a business to run, so time is limited..
    Project: '82, GA61 XX
    Duct Tape Solves All Conversion King ivandude's Avatar
    Jan 2010
    Bitsa, let us know what info you do find out.
    I've had a BHG 1 year ago/20,000km's ago, was a tiny crack in the heads and since had a bottom-end heads rebuild etc. I know my timing chain hasn't been replaced, but no milky water since anyway. It is noisy, not sure what the noises are, but it never over heats so it's been good to me.
    Information about your situation is useful to know. Thanks
    1982 Soarer MZ11 1JZ-GE VVTi build
    1981-1985 Z10 Soarer Owners International Group
    Former rides ~~ RA65 '85 Celica ~ MA61 '84 Supra ~ JZA80 '98 Aerotop ~ AE101 '92 Levin Toyo4life
    south austraila
    Hmmmm ... noise..
    The 22R motors are known for there crapy timing guides.. PLASTIC ...
    when they get old & brake the timing chain then uses the inside edge of the tining cover as a guide.. well Big Noise ... & after a short time it will put 2 x deep "train track" grooves into it.. it will then Crack... Note :- where it will crack is on the High Pressure side of your water pump..... then Presto "iced coffee"
    You can buy rubber backed Steal timing guides these days....
    iconoclast Backyard Mechanic Youngy's Avatar
    There is heaps of info on this issue on the net. Even youtube videos.
    One place to get a metal backed timing chain kit from is - http://www.engnbldr.com/
    I have used one before and it was pretty good for the money I paid and I had no issues.
    Nov 2008
    Quote Originally Posted by ivandude View Post
    No worries mate.
    I'm hoping my problem is the timing cover. I shattered the passengers side guide rail days before I discovered a cracked head. I did put egnbldr's steel guide rail in though I didn't replace the timing cover even though there were two very deep grooves in it, but, I didn't because there didn't appear to be a crack in it. Maybe there is.
    Have bought the 22re out of 86rona's Avante and will be swapping the timing cover and hopefully that will fix my problem for now. Whatever the outcome I'll be doing that motor up as it's only done 300,000 where mine's done 466,000 or I should be able to at least get a decent motor out of the two.
    Thanks for the replies.
    Nov 2008
    Bit of a problem.
    While pulling apart the motor I just bought, I've rounded off the crankshaft/harmonic balancer nut. Tough buggers to get out, especially when they're not in a car. The 19mm socket won't grip enough now.
    Anyone know the best way to remove it ?
    soak it with yield or RP7, WD40 for a while to help loosen the thread and then sacrifice the thing with vice grips - buy a new one after that.
    When you put the thing back together use some cooper coat so it will be easier next time.
    Oct 2008
    TAS
    if you only have a 12 point socket get hold of a 19mm impact socket or 6 sided socket, failing that
    weld a new nut to it,
    1983 Toyota Celica Supra
    Nov 2008
    Thanks for the replies here men. Have soaked it in RP7 and bought a 6 sided socket. That socket doesn't slip at all, but, still can't budge the nut. I need a longer breaker bar to get more leverage, but, that can wait a while as my water in the oil problem wasn't what I thought it was i.e. a damaged timing cover.
    Turns out that I didn't completely drain the motor of the milky oil when I first blew the head gasket.
    That was a bit weird because I drained the oil, then after waiting 3 weeks to get some parts, I undid the sump plug again to put a new gasket on it and water then oil poured out again. Surely it was drained of all oil and water after that though apparently not.
    Moral to that story is maybe put some cheap oil in it after you've replaced the head gasket thereby not ruining your good oil by still having water in the oil passages somewhere when you refill. Put the good stuff in after you've done 100k or so with the cheap stuff.
    One more thing. What a delightful little cam for a 22re that 261c is from engnbldr. A little extra early ooomph at a very reasonable price. Was a waste of time having the standard cam.
    One more thing. I was raised on Repco. If you wanted a part you went to Repco. Nowadays they seem to be more into stereos and car seats than mechanical parts. Today I discovered we have a Bursons in Newcastle and they have mechanical parts coming out their ears, even for my old Corona. Thumbs up to them, but, don't go there if you're after bling, they got none, thank (expletive deleted).
    M M M My Corona Grease Monkey ChArMs's Avatar
    Jun 2006
    Quote Originally Posted by Youngy View Post
    is there any places like this in sydney ? i might be after a new performance head
    Delta Blue RT142 Corona Avante
    south austraila
    Quote Originally Posted by ChArMs View Post
    hmmmm...
    well you can buy New 22R heads, & then find a machine shop to do the haed job..
    But you can Not buy Performance parts for these motors here in Australia..
    eg. Double Row Valve Springs, Hot Cam's, & fancy parts..
    best to PM me for a phone number.. then ring me, i'll give details..
    cheers..
    Mar 2010
    LC Engineering do great work. You can try their website at http://www.lcengineering.com/
    But they're all the way in the states. Maybe if you find a few guys needing parts from there you can save on shipping?
    another possible option - also in the States.
    http://www.22reperformance.com/22RE%...20Engines.html
    but at current rates even shipping of a head will be cheaper than what you can get a reco job for here.
  1. Golberg’s 4AGE 16V Cooling Guide - Lots of Photos!!
    By Golberg in forum Tech and Conversions
    Last Post: 28-01-2009, 09:26 PM
  2. oil temp vs water temp
    By PlacentaJuan in forum Tech and Conversions
    Last Post: 31-03-2008, 08:15 AM
  3. Running without Thermostat - Cools better?
    By kylestyleup in forum Tech and Conversions
    Last Post: 21-01-2008, 07:56 AM
  4. Cooling Systems - Overheating Problems.
