Page 37 of 65 FirstFirst ... 27353637383947 ... LastLast
Results 541 to 555 of 975
Thread: Winton 6 hour 23-24 oct 2010
  1. #541
    Default Re: Winton 6 hour 23-24 oct 2010
    Andrew, max and I changed the clutch plate in the white 22 yesterday. Andrew also, rejetted the carbies. We'll stick in the rca's today and then it's ready to roll at the tampered day and then the 6hr.
    Sorted a few more issues on mine too.
  2. #542
    Eltham vic
    i had a productive day on the blue shitter today
    i did nothing
    , except that i am quite a few beers light in the shed fridge
    no i am telling fibs again
    the bonnet and front guards on the club car is repaired and ready for high fill
    the f/glass front bumper is ready for paint
    the rear bar thanks to PAC is now painted and fitted
    thats it for now
  3. #543
    Retract my statement from ealier. The white 22 has issues- compression results as follows:
    1- 200 2- 200 3- 50 4- 200
    This combined with stacks of blowby led us to believe perhaps a ring had failed. Removal of head and then piston 3 showed broken piston, rather than broken rings. Strange markings on the intake side valve reliefs would suggest valves hitting- but the valves show no signs of hitting. Next idea was sticky valves- bit it does have rr4 performance double valve springs. Final idea was detonation and potentially shitty piston.
    Bottom line - it needs another rebuild.
  4. #544
    Nov 2007
    Quote Originally Posted by shelldrake View Post
    Bugger the shitfight before, I was farken offended when we discovered this bollocks.
  5. #545
    Simon's got a spare 3SGTE he'll lend ya
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
  6. #546
    Eltham vic
    what engine is in the 22 edd
  7. #547
    3t/2tg hybrid...
  8. #548
    Eltham vic
    do you think that you will have the engine rebuilt in time
  9. #549
    Nov 2007
    If we can get pistons and have them flycut this week we should make the tampered day. We also need a head gasket, 3tc one will do in a pinch but prefer 2tg/3tg? Ed can clarify.
    The most difficult part is getting to the bottom of the cause.
  10. #550
    My car runs again!
    Need to make some adjustments to the timing or starting throttle position, as the throttle needs to be opened whilst starting and held open to allow it to continue running.
    At least I'm now on track to have it out next track day.
    So what is the benifit to running the Tampered Motorsport Day next Sunday (26/9), instead of the Winton Test and Tune Day next Friday (24/9)?
    The Tampered days are double the price aren't they?
    ([][][]II--LT--II[][][])
  11. #551
    Eltham vic
    good news simon
    bring it to the coffee and donuts run next sunday
  12. #552
    Nov 2007
    Quote Originally Posted by twentyEight View Post
    They are around $165 from memory. Ed won't make it to the Friday and I'm out for the week after that, plus the white car is in ICU and we'll need that Fri/Sat to sort her out.
  13. #553
    Also, unless you have leave you can take, the Friday equates to a day of lost earnings. I'd like to come watch, but i can't afford to take another Friday off.
    Simon.
    1991 Toyota Cressida (JZX83).
  14. #554
    $165 isn't so bad... I thought they were about $240...
    They're a timed day also yeah?
    Track day next Sunday it is...
  15. #555
    Race car won't start >.<
    Plugs are blacker than the night so gonna get some cheapies to get it going and its booked in to get carbies tuned on monday. Suspect thats why it was struggling to idle after the last couple of runs.
    Mr Shabadoo.
    Daily JZX100
  1. Winton 24 Hour Relay - Easter 2010
    Last Post: 03-03-2010, 05:08 PM
  2. WInton Drift Practice
